I tried to disable MMU before control gives to Linux kernel.
So the flow is,
U-boot Spl -> ATF -> U-boot -> Bootloader -> Payload -> Linux kernel
End of payload we give control to Linux kernel. Before giving control kernel we need to disable MMU.
I use the below code to disable MMU and the results, kernel gives warning and hang.
Solved! Go to Solution.
You can disable from kernel menu config or variable CONFIG_MMU (default value y)in the Kconfig file.
