Hi All,
In my application, the system has hung and needs to be powered on again to recover. I need to find the root cause, so I plan to reset the chips one by one to check for the problem. But I haven't found any register that can reset TN5110 to the default.
Is there any effective way to reset PTN5110?
PTN5110 does not have reset pin or a soft reset. The only way to reset the PTN5110 is by power cycle VDD.
