How can I control PTN36241B by using I2C?
chan_nxp
To whom may it concern,
I'm a H/W circuit designer and using your product, PTN36241B, on my PBA.
I choice below configuration for (maybe loose) setting
 AEQ/BEQ : PU
 ADE/BDE : PD    (=ADD : PD)
 AOS/BOS : VCC
 SQTH : Open
 * PU(Pull-down), PU(Pull-up), VCC(short to VCC), Open(Floating)
But, I'm not sure that it is working.
So, I have I2C host emulator (AARDVARK made by Total Phase)
Link: https://www.totalphase.com/media/wysiwyg/control-center/ControlCenterSerial-I2CGPIOmode.png
 and I try to find proper configuration for operation.
I want to know process for test and tune PTN36241B by the I2C emulator.
Do you have any manual?
guoweisun
HI
You can according the datasheet page9  8.4 I2C-bus programmability to set your desire configuration.
For the I2C-bus read and write sequences please refer to page12.
