When running a USB host example I am only getting 1.6 volts to the J16 USB connector. Can someone please help?
I solved the problem. I had to install a jumper on J22 to activate the chip NCP380.
I am glad to hear that you have solved the issue by closing J22 so that the NCP380 can provide power for the USN host V_BUS pin of usb connector.
XiangJun Rong
