We have faced Enumeration failure in MIMXRT1062DVL6B part ,If will try to connect the host to USB camera board will get continues rest in controller side .
This issue will observed few controller only
You seem to be encountering an enumeration failure with the MIMXRT1062DVL6B when connecting it to a USB camera board, leading to continuous controller resets. This issue is limited to a few controllers.
To address this problem, check the following:
If these steps don't resolve the issue, reach out to the manufacturer or supplier of the USB camera board for further troubleshooting or a firmware update.
