Can the surround view product use a different pattern?
3412
Hello, nxp staff. The current surround view product uses patterns as big black squares with small white squares inside. Can the product be calibrated using a different pattern? If I want to use different patterns, for instance, triangles, what extra work should i consider? Thanks!
jimmychan
For the surround view application, please consider the S32V processors.
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/s32v2-processors-for-vis...
