CONNECTIONS REGARDING VENTILATOR DRM127
jagannathang
How to connect tank flow sensor and what component to be used for the same.
How to connect lung flow and lung pressure sensors and what components to be used?
How is the connection for expiration system?
vicentegomez
I am not sure if I got properly your questions
You need to know the material that was used to plug the sensor to the system? if this is the case, we used a simple plastics pipe, remember this is a demonstration reference design it did not develop with the proposal to be used as a final product.
Vicente Gomez
