Hi. As I correct understand that the 56F8322 can be programming via Flash_over_jtag_v2 tool ? Can you provide good link?
In Flash_over_jtag_v2 tool exist only one *cfg files (flash801x.cfg) and with that *cfg can't to read\write cause wrong PRAM base address. As I see, the *cfg is not usabile for 56F8322. So, please, can you provide exaple *cfg for 56F8322?
