The IVOR1 IRQ is caused by SPC5746R triggering an interrupt.
Jasting
I am currently using the SPC5746RMMT5 chip and enter the IVOR1_IRQ interrupt when debugging eTPU set2 using "S32 DS for Power".
The TG function is working fine for now, but when I set the Crank capture interrupt, it triggers the IVOR1_IRQ interrupt.
Check that the MCSR is not incorrectly set.
What should I do next!
davidtosenovjan
Jasting
