Parking AID Block Diagram
Description
An ultrasonic-based measurement or a camera implementation are a key part of applications dealing with non-contact object distance measurement and object detection, like an automotive parking distance sensor, blind spot detection and object detection.
For an ultrasonic implementation, the S12ZVC integrates a 16-bit MCU, automotive voltage regulator, CAN physical layer, and high-speed timers with input capture and output compare, making it a single chip solution for low-end parking aid systems.
For a camera implementation, the i.MX 8 applications processor along with the S32V234 vision processor offers the power required for image processing and intercommunication between multiple cameras and modules.
Features
  • Automotive voltage regulator
  • CAN physical layer
  • High speed timers with input capture and output compare
  • Ultrasonic technology or cameras for the detection and avoidance of close objects
Block Diagram
Products
Category Name 1:
MCU
Product URL 1
S12ZVC Mixed-Signal MCUs|MagniV | NXP
Product Description 1
The S12ZVC platform, part of the S12 MagniV® mixed-signal MCU family, offers a low-cost, highly integrated solution that enables the design of smallest possible automotive CAN-termination nodes, while the family concept gives you scalability for platform design.
Product URL 2
i.MX 8 Family Applications Processor | Arm Cortex-A53/A72/M4 | NXP
Product Description 2
Fast multi-OS platform deployment via advanced full-chip hardware virtualization and domain protection. Incorporate vision and speech recognition interactivity via a powerful vision pipeline and audio processing subsystem.
Product URL 3
S32V234 Vision Processor | NXP
Product Description 3
The S32V234 MPU offers an Image Signal Processor (ISP), powerful 3D Graphic Processor Unit (GPU), dual APEX-2 vision accelerators, automotive-grade reliability, functional safety, and security capabilities for supporting computation intensive ADAS, NCAP front camera, object detection and recognition, surround view, and automotive image processing.
Category Name 2:
Ethernet
Product URL 1
SJA 110EL | Five ports AVB Automotive Ethernet Switch | NXP
The SJA1105EL Ethernet switch offers a flexible solution for implementing modular and cost-optimized ECUs capable of supporting any in-vehicle connectivity requirement.
Product URL 2
TJA1101 | 2nd generation PHY Transceiver | NXP
TJA1101 is a high-performance single port, IEEE 100BASE-T1 compliant Ethernet PHY Transceiver.
Product URL 3
TJA1102/TJA1102S | Automotive Ethernet Transceivers | NXP
Product Description
TJA1102 (TJA1102S) is a highly integrated dual (respectively single) port, IEEE 100BASE-T1 compliant Ethernet PHY Transceiver.
Category Name 3:
Power Management
Product URL 1
PMIC for high-performance applications | NXP
The PF8100/PF8200 PMIC family is designed for high-performance processing applications such as infotainment, telematics, clusters, vehicle networking, ADAS, vision and sensor fusion.
Category Name 4:
CAN
Product URL 1
TJA1057 | High speed CAN transceiver | NXP
The TJA1057 is part of the Mantis family of high-speed CAN transceivers. It provides an interface between a Controller Area Network (CAN) protocol controller and the physical two-wire CAN bus.
Documentation
S32R Radar Signal Compression: https://www.nxp.com/docs/en/application-note/AN5375.pdf
Tools
Product Link
DEVKIT-S12ZVC: Development Board for 9S12ZVCA192 MCU Evaluation DEVKIT-S12ZVC development platform for S12ZVC | NXP
MCIMX8QM-CPU: i.MX 8QuadMax Multisensory Enablement Kit (MEK) i.MX 8QuadMax/QuadPlus Multisensory Enablement Kit | NXP
S32V234EVB: S32V Vision and Sensor Fusion Evaluation System S32V Vision and Sensor Fusion Evaluation System | NXP
OM14500-TJA1102: Evaluation Board, TJA1102HN 100BASE-T1 Automotive Ethernet PHY TJA1102/S Evaluation Board | NXP
SJA1105Q-EVB: Ethernet Switch & PHY Evaluation Board. SJA1105Q-EVB | Ethernet Switch and PHY Evaluation Board | NXP
标签 (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1123964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%81%9C%E8%BD%A6%E8%BE%85%E5%8A%A9%E7%B3%BB%E7%BB%9F%E6%A1%86%E5%9B%BE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FParking-AID-Block-Diagram%2Fta-p%2F1123964%23toc-hId-382430229%22%20target%3D%22_blank%22%3E%E6%8F%8F%E8%BF%B0%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FParking-AID-Block-Diagram%2Fta-p%2F1123964%23toc-hId--1425024234%22%20target%3D%22_blank%22%3E%E7%89%B9%E6%80%A7%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FParking-AID-Block-Diagram%2Fta-p%2F1123964%23toc-hId-1062488599%22%20target%3D%22_blank%22%3E%E7%BB%93%E6%9E%84%E6%A1%86%E5%9B%BE%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FParking-AID-Block-Diagram%2Fta-p%2F1123964%23toc-hId--744965864%22%20target%3D%22_blank%22%3E%E4%BA%A7%E5%93%81%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FParking-AID-Block-Diagram%2Fta-p%2F1123964%23toc-hId-1742546969%22%20target%3D%22_blank%22%3E%E6%96%87%E6%A1%A3%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FParking-AID-Block-Diagram%2Fta-p%2F1123964%23toc-hId--64907494%22%20target%3D%22_blank%22%3E%E5%B7%A5%E5%85%B7%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId-382430229%22%20id%3D%22toc-hId-1303359384%22%3E%E6%8F%8F%E8%BF%B0%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%9F%BA%E4%BA%8E%E8%B6%85%E5%A3%B0%E6%B3%A2%E7%9A%84%E6%B5%8B%E9%87%8F%E6%88%96%E6%91%84%E5%83%8F%E5%A4%B4%E5%AE%9E%E7%8E%B0%E6%98%AF%E5%A4%84%E7%90%86%E9%9D%9E%E6%8E%A5%E8%A7%A6%E5%BC%8F%E7%89%A9%E4%BD%93%E8%B7%9D%E7%A6%BB%E6%B5%8B%E9%87%8F%E5%92%8C%E7%89%A9%E4%BD%93%E6%A3%80%E6%B5%8B%E5%BA%94%E7%94%A8%E7%9A%84%E5%85%B3%E9%94%AE%E9%83%A8%E5%88%86%EF%BC%8C%E4%BE%8B%E5%A6%82%E6%B1%BD%E8%BD%A6%E5%81%9C%E8%BD%A6%E8%B7%9D%E7%A6%BB%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%81%E7%9B%B2%E7%82%B9%E6%A3%80%E6%B5%8B%E5%92%8C%E7%89%A9%E4%BD%93%E6%A3%80%E6%B5%8B%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%AF%B9%E4%BA%8E%E8%B6%85%E5%A3%B0%E6%B3%A2%E5%AE%9E%E7%8E%B0%EF%BC%8CS12ZVC%20%E9%9B%86%E6%88%90%E4%BA%86%2016%20%E4%BD%8D%20MCU%E3%80%81%E6%B1%BD%E8%BD%A6%E7%94%B5%E5%8E%8B%E8%B0%83%E8%8A%82%E5%99%A8%E3%80%81CAN%20%E7%89%A9%E7%90%86%E5%B1%82%E5%92%8C%E5%85%B7%E6%9C%89%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%E5%92%8C%E8%BE%93%E5%87%BA%E6%AF%94%E8%BE%83%E5%8A%9F%E8%83%BD%E7%9A%84%E9%AB%98%E9%80%9F%E5%AE%9A%E6%97%B6%E5%99%A8%EF%BC%8C%E4%BD%BF%E5%85%B6%E6%88%90%E4%B8%BA%E4%BD%8E%E7%AB%AF%E5%81%9C%E8%BD%A6%E8%BE%85%E5%8A%A9%E7%B3%BB%E7%BB%9F%E7%9A%84%E5%8D%95%E8%8A%AF%E7%89%87%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%AF%B9%E4%BA%8E%E6%91%84%E5%83%8F%E5%A4%B4%E5%AE%9E%E7%8E%B0%EF%BC%8Ci.MX%208%20%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%8E%20S32V234%20%E8%A7%86%E8%A7%89%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%80%E8%B5%B7%E6%8F%90%E4%BE%9B%E4%BA%86%E5%9B%BE%E5%83%8F%E5%A4%84%E7%90%86%E4%BB%A5%E5%8F%8A%E5%A4%9A%E4%B8%AA%E6%91%84%E5%83%8F%E5%A4%B4%E5%92%8C%E6%A8%A1%E5%9D%97%E4%B9%8B%E9%97%B4%E7%9B%B8%E4%BA%92%E9%80%9A%E4%BF%A1%E6%89%80%E9%9C%80%E7%9A%84%E8%83%BD%E5%8A%9B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--1425024234%22%20id%3D%22toc-hId--504095079%22%3E%E7%89%B9%E6%80%A7%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%E6%B1%BD%E8%BD%A6%E7%94%B5%E5%8E%8B%E8%B0%83%E8%8A%82%E5%99%A8%3C%2FLI%3E%0A%3CLI%3ECAN%E7%89%A9%E7%90%86%E5%B1%82%3C%2FLI%3E%0A%3CLI%3E%E5%85%B7%E6%9C%89%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%E5%92%8C%E8%BE%93%E5%87%BA%E6%AF%94%E8%BE%83%E5%8A%9F%E8%83%BD%E7%9A%84%E9%AB%98%E9%80%9F%E5%AE%9A%E6%97%B6%E5%99%A8%3C%2FLI%3E%0A%3CLI%3E%E7%94%A8%E4%BA%8E%E6%A3%80%E6%B5%8B%E5%92%8C%E9%81%BF%E5%BC%80%E8%BF%91%E8%B7%9D%E7%A6%BB%E7%89%A9%E4%BD%93%E7%9A%84%E8%B6%85%E5%A3%B0%E6%B3%A2%E6%8A%80%E6%9C%AF%E6%88%96%E6%91%84%E5%83%8F%E5%A4%B4%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1062488599%22%20id%3D%22toc-hId-1983417754%22%3E%E7%BB%93%E6%9E%84%E6%A1%86%E5%9B%BE%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F94334iC203DC8F6555135B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--744965864%22%20id%3D%22toc-hId-175963291%22%3E%E4%BA%A7%E5%93%81%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E7%B1%BB%E5%88%AB%E5%90%8D%E7%A7%B01%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20920px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMCU%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20920px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fadditional-architectures%2Fs12-magniv-mixed-signal-mcus%2Fs12zvc-mixed-signal-mcu-for-automotive-industrial-can-applications%3AS12ZVC%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fadditional-architectures%2Fs12-magniv-mixed-signal-mcus%2Fs12zvc-mixed-signal-mcu-for-automotive-industrial-can-applications%3AS12ZVC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES12ZVC%20%E6%B7%B7%E5%90%88%E4%BF%A1%E5%8F%B7%20MCU%7CMagniV%20%7C%20NXP%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20920px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ES12ZVC%E5%B9%B3%E5%8F%B0%E6%98%AFS12%20MagniV%C2%AE%E6%B7%B7%E5%90%88%E4%BF%A1%E5%8F%B7MCU%E7%B3%BB%E5%88%97%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%EF%BC%8C%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%AA%E4%BD%8E%E6%88%90%E6%9C%AC%E3%80%81%E9%AB%98%E9%9B%86%E6%88%90%E5%BA%A6%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E6%94%AF%E6%8C%81%E5%AE%A2%E6%88%B7%E8%AE%BE%E8%AE%A1%E5%B0%8F%E5%B0%BA%E5%AF%B8%E7%9A%84%E6%B1%BD%E8%BD%A6CAN%E7%BB%88%E7%AB%AF%E8%8A%82%E7%82%B9%EF%BC%8C%E5%90%8C%E6%97%B6%E8%BF%99%E4%B8%AA%E7%B3%BB%E5%88%97%E7%9A%84%E6%A6%82%E5%BF%B5%E8%BF%98%E4%B8%BA%E5%B9%B3%E5%8F%B0%E8%AE%BE%E8%AE%A1%E6%8F%90%E4%BE%9B%E4%BA%86%E5%85%85%E5%88%86%E7%9A%84%E5%8F%AF%E6%89%A9%E5%B1%95%E6%80%A7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20920px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-8-processors%2Fi.mx-8-family-arm-cortex-a53-cortex-a72-virtualization-vision-3d-graphics-4k-video%3Ai.MX8%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-8-processors%2Fi.mx-8-family-arm-cortex-a53-cortex-a72-virtualization-vision-3d-graphics-4k-video%3Ai.MX8%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%208%20%E7%B3%BB%E5%88%97%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%20%7C%20Arm%20Cortex-A53%2FA72%2FM4%20%7C%20NXP%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20920px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E9%80%9A%E8%BF%87%E5%85%88%E8%BF%9B%E7%9A%84%E5%85%A8%E8%8A%AF%E7%89%87%E7%A1%AC%E4%BB%B6%E8%99%9A%E6%8B%9F%E5%8C%96%E5%92%8C%E5%9F%9F%E4%BF%9D%E6%8A%A4%E5%BF%AB%E9%80%9F%E9%83%A8%E7%BD%B2%E5%A4%9A%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E5%B9%B3%E5%8F%B0%E3%80%82%E9%80%9A%E8%BF%87%E5%BC%BA%E5%A4%A7%E7%9A%84%E8%A7%86%E8%A7%89%E7%AE%A1%E9%81%93%E5%92%8C%E9%9F%B3%E9%A2%91%E5%A4%84%E7%90%86%E5%AD%90%E7%B3%BB%E7%BB%9F%E7%BB%93%E5%90%88%E8%A7%86%E8%A7%89%E5%92%8C%E8%AF%AD%E9%9F%B3%E8%AF%86%E5%88%AB%E4%BA%A4%E4%BA%92%E6%80%A7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20920px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fs32v2-vision-mpus-%2Fvision-processor-for-front-and-surround-view-camera-machine-learning-and-sensor-fusion%3AS32V234%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fs32v2-vision-mpus-%2Fvision-processor-for-front-and-surround-view-camera-machine-learning-and-sensor-fusion%3AS32V234%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32V234%E8%A7%86%E8%A7%89%E5%A4%84%E7%90%86%E5%99%A8%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20920px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ES32V234%20MPU%20%E6%8F%90%E4%BE%9B%E5%9B%BE%E5%83%8F%E4%BF%A1%E5%8F%B7%E5%A4%84%E7%90%86%E5%99%A8%20(ISP)%E3%80%81%E5%BC%BA%E5%A4%A7%E7%9A%84%203D%20%E5%9B%BE%E5%BD%A2%E5%A4%84%E7%90%86%E5%99%A8%E5%8D%95%E5%85%83%20(GPU)%E3%80%81%E5%8F%8C%20APEX-2%20%E8%A7%86%E8%A7%89%E5%8A%A0%E9%80%9F%E5%99%A8%E3%80%81%E6%B1%BD%E8%BD%A6%E7%BA%A7%E5%8F%AF%E9%9D%A0%E6%80%A7%E3%80%81%E5%8A%9F%E8%83%BD%E5%AE%89%E5%85%A8%E6%80%A7%E5%92%8C%E5%AE%89%E5%85%A8%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%94%AF%E6%8C%81%E8%AE%A1%E7%AE%97%E5%AF%86%E9%9B%86%E5%9E%8B%20ADAS%E3%80%81NCAP%20%E5%89%8D%E7%BD%AE%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%81%E7%89%A9%E4%BD%93%E6%A3%80%E6%B5%8B%E5%92%8C%E8%AF%86%E5%88%AB%E3%80%81%E7%8E%AF%E8%A7%86%E8%A7%86%E5%9B%BE%E5%92%8C%E6%B1%BD%E8%BD%A6%E5%9B%BE%E5%83%8F%E5%A4%84%E7%90%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E7%B1%BB%E5%88%AB%E5%90%8D%E7%A7%B02%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20921px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20921px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-switches%2Ffive-ports-avb-automotive-ethernet-switch%3ASJA1105EL%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-switches%2Ffive-ports-avb-automotive-ethernet-switch%3ASJA1105EL%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESJA%20110EL%20%7C%20%E4%BA%94%E7%AB%AF%E5%8F%A3%20AVB%20%E6%B1%BD%E8%BD%A6%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BA%A4%E6%8D%A2%E6%9C%BA%20%7C%20NXP%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20921px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESJA1105EL%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BA%A4%E6%8D%A2%E6%9C%BA%E6%8F%90%E4%BE%9B%E7%81%B5%E6%B4%BB%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E5%8F%AF%E5%AE%9E%E7%8E%B0%E6%A8%A1%E5%9D%97%E5%8C%96%E5%92%8C%E6%88%90%E6%9C%AC%E4%BC%98%E5%8C%96%E7%9A%84ECU%EF%BC%8C%E8%83%BD%E5%A4%9F%E6%94%AF%E6%8C%81%E4%BB%BB%E4%BD%95%E8%BD%A6%E8%BD%BD%E8%BF%9E%E6%8E%A5%E8%A6%81%E6%B1%82%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20921px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1101%20%7C%20%E7%AC%AC%E4%BA%8C%E4%BB%A3%20PHY%20%E6%94%B6%E5%8F%91%E5%99%A8%20%7C%20NXP%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20921px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETJA1101%E6%98%AF%E4%B8%80%E6%AC%BE%E9%AB%98%E6%80%A7%E8%83%BD%E5%8D%95%E7%AB%AF%E5%8F%A3%E3%80%81%E7%AC%A6%E5%90%88IEEE%20100BASE-T1%E6%A0%87%E5%87%86%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91PHY%E6%94%B6%E5%8F%91%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20921px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2Ftja1102-tja1102s-ieee-100base-t1-compliant-ethernet-phy-transceivers%3ATJA1102-TJA1102S%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2Ftja1102-tja1102s-ieee-100base-t1-compliant-ethernet-phy-transceivers%3ATJA1102-TJA1102S%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1102%2FTJA1102S%20%7C%20%E6%B1%BD%E8%BD%A6%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%94%B6%E5%8F%91%E5%99%A8%20%7C%20NXP%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20921px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETJA1102%20(TJA1102S)%E6%98%AF%E9%AB%98%E5%BA%A6%E9%9B%86%E6%88%90%E7%9A%84%E5%8F%8C(%E5%88%86%E5%88%AB%E4%B8%BA%E5%8D%95%E4%B8%AA)%E7%AB%AF%E5%8F%A3%E4%BB%A5%E5%A4%AA%E7%BD%91PHY%E6%94%B6%E5%8F%91%E5%99%A8%EF%BC%8C%E7%AC%A6%E5%90%88IEEE%20100BASE-T1%20%E6%A0%87%E5%87%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E7%B1%BB%E5%88%AB%E5%90%8D%E7%A7%B0%203%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20919px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20919px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F12-channel-power-management-integrated-circuit-pmic-for-high-performance-processing-applications%3APF8100-PF8200%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F12-channel-power-management-integrated-circuit-pmic-for-high-performance-processing-applications%3APF8100-PF8200%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E9%80%82%E7%94%A8%E4%BA%8E%E9%AB%98%E6%80%A7%E8%83%BD%E5%BA%94%E7%94%A8%E7%9A%84PMIC%20%7C%20NXP%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20919px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EPF8100%2FPF8200%20PMIC%E7%B3%BB%E5%88%97%E4%B8%93%E4%B8%BA%E9%AB%98%E6%80%A7%E8%83%BD%E5%A4%84%E7%90%86%E5%BA%94%E7%94%A8%E8%80%8C%E8%AE%BE%E8%AE%A1%EF%BC%8C%E5%A6%82%E4%BF%A1%E6%81%AF%E5%A8%B1%E4%B9%90%E3%80%81%E8%BD%A6%E8%BD%BD%E4%BF%A1%E6%81%AF%E6%9C%8D%E5%8A%A1%E3%80%81%E4%BB%AA%E8%A1%A8%E6%9D%BF%E3%80%81%E8%BD%A6%E8%BE%86%E7%BD%91%E7%BB%9C%E3%80%81ADAS%E3%80%81%E8%A7%86%E5%9B%BE%E5%92%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E8%9E%8D%E5%90%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E7%B1%BB%E5%88%AB%E5%90%8D%E7%A7%B0%204%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20917px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECAN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E7%BD%91%E5%9D%80%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20917px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fhigh-speed-can-transceiver-mantis-family%3ATJA1057%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fhigh-speed-can-transceiver-mantis-family%3ATJA1057%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1057%20%7C%20%E9%AB%98%E9%80%9FCAN%E6%94%B6%E5%8F%91%E5%99%A8%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2050px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2050px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%BA%A7%E5%93%81%E6%8F%8F%E8%BF%B0%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20917px%3B%20height%3A%2050px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETJA1057%E6%98%AFMantis%E7%B3%BB%E5%88%97%E9%AB%98%E9%80%9FCAN%E6%94%B6%E5%8F%91%E5%99%A8%E4%B8%AD%E7%9A%84%E4%B8%80%E5%91%98%E3%80%82%20%E5%AE%83%E5%8F%AF%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B1%80%E5%9F%9F%E7%BD%91%EF%BC%88CAN%EF%BC%89%E5%8D%8F%E8%AE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E7%89%A9%E7%90%86%E5%8F%8C%E7%BA%BF%E5%BC%8FCAN%E6%80%BB%E7%BA%BF%E4%B9%8B%E9%97%B4%E6%8F%90%E4%BE%9B%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1742546969%22%20id%3D%22toc-hId--1631491172%22%3E%E6%96%87%E6%A1%A3%3C%2FH1%3E%0A%3CP%3ES32R%E9%9B%B7%E8%BE%BE%E4%BF%A1%E5%8F%B7%E5%8E%8B%E7%BC%A9%EF%BC%9A%20%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5375.pdf%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5375.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5375.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--64907494%22%20id%3D%22toc-hId-856021661%22%3E%E5%B7%A5%E5%85%B7%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%2352cc8f%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2044.771%25%3B%22%3E%E4%BA%A7%E5%93%81%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2053.3276%25%3B%22%3E%E9%93%BE%E6%8E%A5%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2044.771%25%3B%22%3EDEVKIT-S12ZVC%EF%BC%9A9S12ZVCA192%20MCU%20%E8%AF%84%E4%BC%B0%E5%BC%80%E5%8F%91%E6%9D%BF%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2053.3276%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs12-magniv-mcu-platforms%2Fdevelopment-board-for-9s12zvca192-mcu-evaluation%3ADEVKIT-S12ZVC%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs12-magniv-mcu-platforms%2Fdevelopment-board-for-9s12zvca192-mcu-evaluation%3ADEVKIT-S12ZVC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDEVKIT-S12ZVC%20%E5%BC%80%E5%8F%91%E5%B9%B3%E5%8F%B0%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20S12ZVC%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2044.771%25%3B%22%3EMCIMX8QM-CPU%3A%20i.MX%208QuadMax%20Multisensory%20Enablement%20Kit%20(MEK)%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2053.3276%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fi.mx-8quadmax-multisensory-enablement-kit-mek%3AMCIMX8QM-CPU%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fi.mx-8quadmax-multisensory-enablement-kit-mek%3AMCIMX8QM-CPU%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%208QuadMax%2FQuadPlus%20%E5%A4%9A%E6%84%9F%E5%AE%98%E6%94%AF%E6%8C%81%E5%A5%97%E4%BB%B6%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2044.771%25%3B%22%3ES32V234EVB%3A%20S32V%E8%A7%86%E8%A7%89%E5%92%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E8%9E%8D%E5%90%88%E8%AF%84%E4%BC%B0%E7%B3%BB%E7%BB%9F%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2053.3276%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32v-mpu-platforms%2Fs32v-vision-and-sensor-fusion-evaluation-system%3AS32V234EVB%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32v-mpu-platforms%2Fs32v-vision-and-sensor-fusion-evaluation-system%3AS32V234EVB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32V%E8%A7%86%E8%A7%89%E5%92%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E8%9E%8D%E5%90%88%E8%AF%84%E4%BC%B0%E7%B3%BB%E7%BB%9F%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2044.771%25%3B%22%3EOM14500-TJA1102%EF%BC%9A%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%8CTJA1102HN%20100BASE-T1%20%E6%B1%BD%E8%BD%A6%E4%BB%A5%E5%A4%AA%E7%BD%91PHY%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2053.3276%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-board-tja1102hn-100base-t1-automotive-ethernet-phy%3AOM14500-TJA1102%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-board-tja1102hn-100base-t1-automotive-ethernet-phy%3AOM14500-TJA1102%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1102%2FS%E8%AF%84%E4%BC%B0%E6%9D%BF%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2044.771%25%3B%22%3ESJA1105Q-EVB%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BA%A4%E6%8D%A2%E6%9C%BA%E5%92%8CPHY%E8%AF%84%E4%BC%B0%E6%9D%BF%E3%80%82%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2053.3276%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fethernet-switch-phy-evaluation-board.%3ASJA1105Q-EVB%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fethernet-switch-phy-evaluation-board.%3ASJA1105Q-EVB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESJA1105Q-EVB%20%7C%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BA%A4%E6%8D%A2%E6%9C%BA%E5%92%8C%20PHY%20%E8%AF%84%E4%BC%B0%E6%9D%BF%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A1%86%E5%9B%BE%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E6%99%BA%E6%85%A7%E5%9F%8E%E5%B8%82%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎10-20-2020 09:27 AM
更新人:
