I am using ULPCD mode in my application. The host needs to wake the PN7642 using GPIO3.
I have tested this but toggling GPIO3 doesn't wake the PN7642 from ULPCD.
The data sheet says the following:
The following EEPROM configuration is available:
• ULPCD_VOLTAGE_CTRL
• ULPCD_RSSI_GUARD_TIME
• ULPCD_RSSI_SAMPLE_CFG
• ULPCD_THRESH_LVL
• ULPCD_GPIO3 - Allows to abort the ULPCD based on GPIO input.
Is there an example of how to configure GPIO3 in the EEPROM so that it is properly enabled?
Thanks.
Hi Mlang:
Could you please let me know how to reproduce this issue with NXP PN7642 EVK board , or only happens on your custom board?
