How to set MIFARE keys via simplified API
jr_hernandez
I am testing the simplified API and I succesfully managed to read mifare card data (within block 5 p.e.) via default key. So far so good.
Now, I would like to authenticate by using other key and I am tryning to set it up in the keyStore, but no succes. The key is set properly (apparently), but then it fails at the MFC_AUTHETICATE(...) when trying to read.
Since I have found no methods for such task in the Simplified API I am using legacy methods to handle keyStore (found inside NfcrdlibEx4_MIFAREClassic example) when initializing NfcLib, but no succes.
Is it possible to handle keyStore via Simplified Api?
Is there any example (apart from NfcrdlibEx4_MIFAREClassic) on how to change, set or add key to the KeyStore?
Regards, Ramon.
