MQX Copilation issue
2,330件の閲覧回数
kirankunnath
When i tried to compile MQX source ( iam using MQX 4.0) using MinGW, its giving an error - "error: stdint.h: No such file or directory".
where is this stdint.h file located? please help me to resolve this issue. Error log is attached.
3 返答(返信)
2,087件の閲覧回数
c0170
Senior Contributor III
Hello kiran kunnath,
what makefile are you using? what's your settings? Because I see Code Red paths on the screen. The stdint header file is not part of MQX. That header file is part of standard library. I assume your path settings are not correct.
0xc0170
2,087件の閲覧回数
kirankunnath
Hello Martin,
When i tried to compile an example code hello (which is in MQX 4.0 examples) using MinGW, compilation error is coming. I have attached the error logs. I would like to know where can i find the gcc version of the files __arm_start.c and __arm_end.c supporting freescale K60 for Redsuite compiler which are missing.
2,087件の閲覧回数
kirankunnath
Could you please provide startup files __arm_start.c and __arm_end.c files supporting freescale K60 for Redsuite compiler.
