How to use PWM to control light on an LED
915 次查看
eugenferaru
System is k60, MQX 3.8.
The MQX_3.8\demo\pe_demo\cw10\pe_demo_twrk60n512 makes a reference to the PWM_Init and PWM_Enable functions.
I have tried to i port this sample project and it does not compile.
Questions:
1. How can the project be imported in CodeWarrior 10.2 and compile?
2. Where are these PWM_Init and PWM_Enable functions defined?
3. How can FTM be used to control light on an LED?
标记 (4)
350 次查看
c0170
Senior Contributor III
Hello Eugen Feraru,
this thread provides some information regarding PWM and MQX:
https://community.freescale.com/message/94112#94112
PWM driver is not part of the MQX therefore there's component you should add to your bsp to have PWM functions available.
Those particular questions are more related to PE than MQX. If you don't receive proper response, please start new thread in PE section and we lock or delete this thread. Thx.
MartinK
351 次查看
c0170
Hello Eugen Feraru,
MartinK
