I'm getting the kernel data error, I suspect, because of a task overflowing. Is there a way to prevent the task stack overrun? In other words, don't let it spill into some other memory but rather just generate an exception and/or block the task.
Oh, and by the way CodeWarrior 7.1.2 has to be killed and restarted when this happens.
Solved! Go to Solution.
in MQX for Freescale we dont support such feature as this feature requires hardware support (MMU) which ColdFire devices lack.
