Freescale MQX™ 4.0.2 Release
The new Freescale MQX™ 4.0.2  release is now available on the www.freescale.com/MQX
·         Files available
Name
Description
1
FSL_MQX_RELEASE_NOTES_4_0_2
Freescale   MQX™ RTOS 4.0.2 Release Notes
2
FSL_MQX__FFS_RELEASE_NOTES_4_0_2
Freescale   MQX™ FFS package 4.0.2 Release Notes
3
FSL_MQX_ATHEROS_RELEASE_NOTES_4_0_2
Freescale   MQX™ Atheros Wifi package 4.0.2 Release Notes
4
Freescale   MQX RTOS 4.0.2 Atheros Wifi package
Atheros   Wifi solution for MQX™ 4.0.2
5
Freescale   MQX RTOS 4.0.2 FFS package
NAND   Flash File System solution for MQX™ 4.0.2
6
MQX™   Source code. Includes an RTOS, File   System, TCP/IP and USB host/device software stacks. Does not require MQX™ 4.0   installation.
·         What is New?
o   AutoEVB Vybrid A5 and M4 Board support packages
§  Support for CortexA5 and CortexM cores of dual core Vybrid processor
§  Supporting standard set of IO drivers
o   Vybrid BSP extensions
§  RTC and NAND flash driver ported to Vybrid platform
§  MMU support extended by handling of 4KB memory block
§  Introduced new QuadSPI driver
§  CortexM4 boot option enabled.
§  Direct code execution from QuadSPI flash – XIP provided. Feature demonstrated in Vybrid QuadSPI bootloader.
Introduced the first version of eDMA driver – the driver is experimental and will be further extended in the next MQX version. Documentation is not provided.
o   Kinetis SPI driver was updated to use the eDMA driver.
o   Hardware timer driver support extended to Systick and GPT HW modules. Kinetis and Vybrid BSPs updated to leverage the Hardware timer to provide MQX tick time.
o   RTCS Hardware checksum acceleration enabled in ENET driver (for TCP and UDP); the benefits are the increased throughput and a reduced processor loading. This option is enabled by default for the K60N512 platform.
o   HTTP server redesigned to provide a faster and more robust solution. The server API is simplified and changed to correspond to the RTCS standard.
o   New SMTP client functionality provided as a part of the RTCS network suite. The client offers a simple API for e-mail handling. The new RTCS Shell command “email” demonstrates its functionality.
o   The security_email, security_webserver, and security_telnet demo applications are removed from this release. Networking functionality is demonstrated in RTCS shell and httpsrv example applications.
o   Multicore Communication (MCC) library updated to version 1.1. Fixed the incorrect usage of cache macros in the mcc_send() function.
·         Known issues
o   For known issues and limitations please consult the release notes.
%3CLINGO-SUB%20id%3D%22lingo-sub-1120447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreescale%20MQX%E2%84%A2%204.0.2%20Release%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22WordSection1%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-left%3A%20120.0pt%3B%20text-indent%3A%20-120.0pt%3B%20tab-stops%3A%20120.0pt%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2C%20sans-serif%3B%20font-size%3A%2011pt%3B%20line-height%3A%201.5em%3B%22%3EThe%20new%20Freescale%20MQX%E2%84%A2%204.0.2%26nbsp%3B%20release%20is%20now%20available%20on%20the%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2FMQX%22%20style%3D%22font-family%3A%20Calibri%2C%20sans-serif%3B%20font-size%3A%2011pt%3B%20line-height%3A%201.5em%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ewww.freescale.com%2FMQX%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level1%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Symbol%3B%20mso-bidi-font-weight%3A%20bold%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Symbol%3B%20mso-fareast-font-family%3A%20Symbol%3B%22%3E%C2%B7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3EFiles%20available%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20class%3D%22MsoNormalTable%22%20style%3D%22width%3A%20761px%3B%20margin-left%3A%20-1.15pt%3B%20border-collapse%3A%20collapse%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%20height%3A%2013.85pt%3B%22%3E%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20background%3A%20black%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2013.85pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CA%20name%3D%22RANGE!B6%3AD12%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20white%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%23%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20background%3A%20black%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2013.85pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20white%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSTRONG%3EName%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20background%3A%20black%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2013.85pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20white%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSTRONG%3EDescription%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20height%3A%2028.25pt%3B%22%3E%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%2012.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFSL_MQX_RELEASE_NOTES_4_0_2%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFreescale%26nbsp%3B%26nbsp%3B%20MQX%E2%84%A2%20RTOS%204.0.2%20Release%20Notes%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%202%3B%20height%3A%2028.25pt%3B%22%3E%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFSL_MQX__FFS_RELEASE_NOTES_4_0_2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFreescale%26nbsp%3B%26nbsp%3B%20MQX%E2%84%A2%20FFS%20package%204.0.2%20Release%20Notes%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%203%3B%20height%3A%2028.25pt%3B%22%3E%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFSL_MQX_ATHEROS_RELEASE_NOTES_4_0_2%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFreescale%26nbsp%3B%26nbsp%3B%20MQX%E2%84%A2%20Atheros%20Wifi%20package%204.0.2%20Release%20Notes%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%204%3B%20height%3A%2028.25pt%3B%22%3E%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFreescale%26nbsp%3B%26nbsp%3B%20MQX%20RTOS%204.0.2%20Atheros%20Wifi%20package%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EAtheros%26nbsp%3B%26nbsp%3B%20Wifi%20solution%20for%20MQX%E2%84%A2%204.0.2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%205%3B%20height%3A%2028.25pt%3B%22%3E%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E5%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFreescale%26nbsp%3B%26nbsp%3B%20MQX%20RTOS%204.0.2%20FFS%20package%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2028.25pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ENAND%26nbsp%3B%26nbsp%3B%20Flash%20File%20System%20solution%20for%20MQX%E2%84%A2%204.0.2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%206%3B%20mso-yfti-lastrow%3A%20yes%3B%20height%3A%2026.0pt%3B%22%3E%3CTD%20style%3D%22width%3A%2028.85pt%3B%20border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2026.0pt%3B%22%20valign%3D%22top%22%20width%3D%2238%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E6%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20195.6pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2026.0pt%3B%22%20valign%3D%22top%22%20width%3D%22261%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EFreescale%26nbsp%3B%26nbsp%3B%20MQX%20RTOS%204.0.2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%20346.3pt%3B%20border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%20height%3A%2026.0pt%3B%22%20valign%3D%22top%22%20width%3D%22462%22%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EMQX%E2%84%A2%26nbsp%3B%26nbsp%3B%20Source%20code.%20Includes%20an%20RTOS%2C%20File%26nbsp%3B%26nbsp%3B%20System%2C%20TCP%2FIP%20and%20USB%20host%2Fdevice%20software%20stacks.%20Does%20not%20require%20MQX%E2%84%A2%204.0%26nbsp%3B%26nbsp%3B%20installation.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level1%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Symbol%3B%20mso-bidi-font-weight%3A%20bold%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Symbol%3B%20mso-fareast-font-family%3A%20Symbol%3B%22%3E%C2%B7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3EWhat%20is%20New%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3EAutoEVB%20Vybrid%3C%2FSTRONG%3E%20A5%20and%20M4%20Board%20support%20packages%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3ESupport%20for%20CortexA5%20and%20CortexM%20cores%20of%20dual%20core%20Vybrid%20processor%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3ESupporting%20standard%20set%20of%20IO%20drivers%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-weight%3A%20bold%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3EVybrid%20BSP%20extensions%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3ERTC%20and%20NAND%20flash%20driver%20ported%20to%20Vybrid%20platform%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EMMU%20support%20extended%20by%20handling%20of%204KB%20memory%20block%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EIntroduced%20new%20QuadSPI%20driver%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3ECortexM4%20boot%20option%20enabled.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level3%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Wingdings%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Wingdings%3B%20mso-fareast-font-family%3A%20Wingdings%3B%22%3E%C2%A7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EDirect%20code%20execution%20from%20QuadSPI%20flash%20%E2%80%93%20XIP%20provided.%20Feature%20demonstrated%20in%20Vybrid%20QuadSPI%20bootloader.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.5in%3B%22%3EIntroduced%20the%20first%20version%20of%20eDMA%20driver%20%E2%80%93%20the%20driver%20is%20experimental%20and%20will%20be%20further%20extended%20in%20the%20next%20MQX%20version.%20Documentation%20is%20not%20provided.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EKinetis%20SPI%20driver%20was%20updated%20to%20use%20the%20eDMA%20driver.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EHardware%20timer%20driver%20support%20extended%20to%20Systick%20and%20GPT%20HW%20modules.%20Kinetis%20and%20Vybrid%20BSPs%20updated%20to%20leverage%20the%20Hardware%20timer%20to%20provide%20MQX%20tick%20time.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3ERTCS%20Hardware%20checksum%20acceleration%20enabled%20in%20ENET%20driver%20(for%20TCP%20and%20UDP)%3B%20the%20benefits%20are%20the%20increased%20throughput%20and%20a%20reduced%20processor%20loading.%20This%20option%20is%20enabled%20by%20default%20for%20the%20K60N512%20platform.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EHTTP%20server%20redesigned%20to%20provide%20a%20faster%20and%20more%20robust%20solution.%20The%20server%20API%20is%20simplified%20and%20changed%20to%20correspond%20to%20the%20RTCS%20standard.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3ENew%20SMTP%20client%20functionality%20provided%20as%20a%20part%20of%20the%20RTCS%20network%20suite.%20The%20client%20offers%20a%20simple%20API%20for%20e-mail%20handling.%20The%20new%20RTCS%20Shell%20command%20%E2%80%9Cemail%E2%80%9D%20demonstrates%20its%20functionality.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EThe%20security_email%2C%20security_webserver%2C%20and%20security_telnet%20demo%20applications%20are%20removed%20from%20this%20release.%20Networking%20functionality%20is%20demonstrated%20in%20RTCS%20shell%20and%20httpsrv%20example%20applications.%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20IT%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EMulticore%20Communication%20(MCC)%20library%20updated%20to%20version%201.1.%20Fixed%20the%20incorrect%20usage%20of%20cache%20macros%20in%20the%20mcc_send()%20function.%3CSPAN%20lang%3D%22IT%22%20style%3D%22mso-ansi-language%3A%20IT%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Symbol%3B%20mso-bidi-font-weight%3A%20bold%3B%20mso-list%3A%20Ignore%3B%20font-family%3A%20Symbol%3B%20mso-fareast-font-family%3A%20Symbol%3B%22%3E%C2%B7%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3EKnown%20issues%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%201.0in%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l0%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22mso-list%3A%20Ignore%3B%20font-family%3A%20'Courier%20New'%3B%20mso-fareast-font-family%3A%20'Courier%20New'%3B%22%3Eo%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EFor%20known%20issues%20and%20limitations%20please%20consult%20the%20release%20notes.%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎08-22-2013 02:23 PM
Updated by:
