the instruction of evstdd generate an exception
tiganhee
my mcu is MPC5644, compile is windriver diab.
question #1:
I decalre a unsigned long long variable  named zz,but the program is run error when the varible zz is wrote by 0x1234567887654321. the address of zz is 0x400000b8. Source code is attchment, pls help me to find the reason of the program generate the excepton.
question #2:
what mean by "EXTZ(UIMM*8) " in the instruction of evstdd , refer to e200z4RM.pdf
pls see to the attachment#2.
thank you verymuch.
lukaszadrapa
1. You need to enable SPE, otherwise an exception is triggered:
2. Here is an explanation from https://www.nxp.com/docs/en/reference-manual/SPEPEM.pdf
Lukas
