In MPC5777C reference manual mentioned about system IO details.xlsx but i am unable to find it in any where. please provide me the those details.@
Thanks&Regards,
Naidu.
Solved! Go to Solution.
Hi Naidu,
See the device I/O Signal table attached to the device Reference Manual as an Excel file. Locate the paperclip symbol on the left side of the PDF window, and click it.
Or open RM and go through menu…
Or simply press CTRL+SHIFT+A. Double-click the Excel file to open it.
Note: not all pdf viewers allows attachments opening.
BR, Petr
Thank you Peter stancik
