adding ADC_pal to freertos - mpc5748g.
Krishnaja
I added hardware trigger part of adc_pal_mpc5748g example to as a freeRTOS project as an rtos task.
It is stuck in this loop. I face this issue only when created as a rtos task??
Please tell me how to resolve it.
Krishnaja.
Krishnaja
Any updates over the query??
PetrS
you got this DevAssert because PIT ch3 is selected for both FreeRTOS tick and ADC HW trigger, and this channel is already started by FreeRTOS. Once started next time by you this devAssert appears. Try to use e.g different PIT channel for FreeRTOS.
BR, Petr
davidtosenovjan
Could you describe which NXP examples is the attached code based on? Thanks
Krishnaja
Any updates?
Krishnaja
To a "freertos_mpc5748g" example, I have added adc component and added hardware trigger part from "adc_pal_mpc5748g" example.
I had created adc task and its task handler in the previously attached project.
PFA
Krishnaja.
