Semaphores and shared memory issue
1,529件の閲覧回数
1329306846
Dear Martin Kovar
Thank you for your answer of my question ! But I still have some questions I want to consult you .
As we know , in a dual-processor chip, semaphores are used to let each processor know who has control of common memory.
I want to know whether the global variable is set default in both core's common memory. If not , can you ask me how to configure shared memory and make global variable in the shared memory .
Hope to get your help !
1,276件の閲覧回数
martin_kovar
Hello, if you want to use semaphores and shared memory you have to do following steps:
1) create shared memory in linker file and place there your own section
    shared :    org = 0x40000000, len = 4k
.sharedRAM (NOLOAD):
      *(.sharedRAM)
    } > shared
2) create global variable for first core and place it to the section in shared memory
tSharedStruct shared_struct __attribute__((section (".sharedRAM")));
3) for second memory, you have to create pointer to global variable
extern tSharedStruct __shared_struct[];
volatile tSharedStruct *px1 = __shared_struct;
 All necessary information regarding linker file are contained in the project I sent you.Please check ld files, c files with main function and sh_mem.h files.
All information about correct semaphores implementation are described in the app note.
Martin
