Hello all,
We tried to put the rf card we developed on the MPC5xxx motherboard and run it but we encountered an error like below. How can we solve this problem? You can see the problem we encountered in the images below.
In this picture even though we commented out the part about rval, we observed that hallErrCode value was changed from 0(No error) to -40 and then it is changed automatically to 0 when code passes to the next check.
Error identified this error code; RSDK_TEF810X_ISMFITFAIL. ( The error code was detected by detecting the value obtained by converting the decimal type of hexademical types in place in the rsdk_status.h code file)
Thanks in advance.
Our RADAR team need more detailed description of the issue in order to support you.
Error -40 refers to interface toggle fail, not to MMIC. This points to MCU related root cause, not MMIC.
please provide more information on what are the ISM FIT flags showing.
Peter
I have contact your RADAR team, they will have look at your issue ASAP.
Peter
