It often error occurs when I run RSDK_demo,the error message is “RSDK_SPT_RET_ERR_DMA”.
I did not change the source code,what is the reason for this error?how to solve it?
I need help,thanks
已解决! 转到解答。
Could you share more details?
We need more information how this issue can be reproduced. Could you post some screenshots also?
Peter
This problem has been solved,I used eeprom by mistake.
thinks for your attention
Why is this error related to eeprom
