Question of SIU.PCR setting for MPC5777C ADC
Luke_Chun
Dear Team
Could you check the question of SIU.PCR setting for MPC5777C ADC?
When I use ADC by MPC5777C, I set-up PA to Primary function(for ADC using).
However I’m not sure that how to control “IBE”.
As far as I know, in case of 5643L, IBE should not set when the pin is used for ADC, but I could not find the infromaiton of 5777C case.
Could you let me know which IBE setting is correct for the using ADC function?
Thank you.
davidtosenovjan
Hi, IBE is not needed to be set.
davidtosenovjan
