Hai,
MPC5746C is getting stuck with a IVOR1_Handler and ADC_ER_IRQHandler after operating normally for 5 hours.
#define configCPU_CLOCK_HZ ( 16000000UL )
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES ( 23 )
FreeRTOS is being used.
Can you help us in this regard?
This is how the registers look like when the IVOR1_Handler occurs.
Ok, so you hava exception on read/write on address 0x12.
Which is expected if you read from reserved area:
Make sure your SW and linker is aligned with your device memory range.
Peter
OK, first of all check the FCCU, for possible faults latched. Registers NCFSx.
Also check MCSR:
Peter
