MPC5744P eTimer1 can be used for measuring the frequency?
608件の閲覧回数
qinxk
Dear,
would you please tell me if eTimer1 also can be used for capturing the PWM signals ?
If yes, how?
ASAP!
3 返答(返信)
603件の閲覧回数
PetrS
yes, it can. Each channel supports capture feature.
Some example can be found on https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/Example-MPC5744P-eTimer-frequency-measurement-GH...
BR, Petr
599件の閲覧回数
qinxk
ok, I tested, It's OK for eTimer0, but NOK for eTimer1, SO is the configure different?
595件の閲覧回数
PetrS
there should be no difference in eTimer channel setting, except of input signal/pin. Which pin do you use in fact and what is the config you have?
BR, Petr
