MPC5744P PWM
已解决
MPC5744P PWM
跳至解决方案
4,063 次查看
woaibaiyan
    I am using the MPC5744P chip now. I want to implement PWM capture on the C[4] pin.
    I used the eTimer module to implement the PWM capture function. But the C[4] pin does not have an eTimer module.
    I don't know how to use the PWM module to implement capture PWM.Could you give me an example to implement        PWM capture with the PWM module? Thank you!
标记 (2)
1 解答
3,877 次查看
PetrS
the capture on teh FlexPWM works simiarly as on eTimer. I can share example for the MPC5643L, you can easily reuse it on the MPC5744P. Take a simple FlexPWM example for MPC5744P and add code for e-capture.
BR, Petr
在原帖中查看解决方案
1 回复
3,878 次查看
PetrS
BR, Petr
