MPC5744, using SDK to configure interrupt priority
ChenBowen
      I am trying to learn SDK. I opened the pit interrupt example in S32DS.  It seems there is no interrupt priority configuration step in your code (or I just missed it).
     I noticed that there is a api function "INT_SYS_SetPriority" in SDK to set the specific irqnumber's priority, but this isn't called in in the project.
petervlna
If there is no interrupt priority set, the interrupt wont be called.
You can have a look at reference example:
https://community.nxp.com/docs/DOC-329575
You can have a look at interrupt processing in reference manual: 21.6.3 Handshaking with processor
I cant speak for unknown example in SDK. Its better always to understand how the interrupt is processed from some bare die example project or manual.
Peter
