How to download .srec file to MPC5777M
yalamandadosaky
Contributor V
Hi I want to download the .srec file to MPC5777M board, which is generated by the S32DS PowerPC V1.1 build options.
is there any parser is required like elf parser ?
petervlna
Just use common JTAG debugger like PEMicro, Lauterbach, PLS, GHS, iSystem or any which supports MPC5777M programming.
Peter
yalamandadosaky
Contributor V
Hi petervlna‌ , Sorry that , Actually My project is Bootloader, so I want to flash the application (.srec file) generated by build options using the bootloader based on ethernet.
So I dont know how to parse(align) this .srec file,  before flashing it onto the MPC5777M board.
So What tools are available for it ? and I am using srec_info tool which is giving two sections .
Format: Motorola S-Record
Header: "Z7_0.srec"
Execution Start Address: 010C0000
Data:   010C10F4 - 010EA29F
        010EE608 - 010EE61B
Can you help me how to align and flash the file ?
