FLEXCAN's IMASK1 be Abnormally cleared
baixiaolin
  i use function (FLEXCAN_DRV_ReceiveBlocking(CANCOM,CAN_RMB,&candata,CAN_RX_TIMEOUT);) by task to receive can message. CAN_RMB correspond to IMASK1 bit be abnormally clear ,due to task is block.In the case of normal,this function(FLEXCAN_StartRxMessageBufferData) will to enable MB interrupt,but it's not success.
  can-receive can resume when enable imask1 bit by debug mode. but it will err when run for some time.
Sorry my English is not so good!
@Senlent
PetrS
which SDK version do you use?
I see there was some fix of driver in SDK3.0.3...
Could this be related?
BR, Petr
baixiaolin
hi
Where do your pictures come from?
PetrS
taken from c:\NXP\S32DS_Power_v2.1\S32DS\software\S32_SDK_S32PA_RTM_3.0.3\S32_SDK_for_Power_Architecture_RTM_3_0_3_Release_Notes.pdf
BR, Petr
baixiaolin
thank you!
baixiaolin
hi
SDK version:sdk 3.0.0
It should be a similar question!How can I solve it?
baixiaolin
add: using FLEXCAN_DRV_SendBlocking and FLEXCAN_DRV_ReceiveBlocking in different task,in addition,time_out set forever.IMASK1 be Abnormally cleared wii due to task block.
