About the suffix of SPC5516 MCUs
enesa22
We use the SPC5516EBMLQ66 MCU in one of our products. We are currently looking for an alternative as we are having problems with its supply. Is the difference between this MCU and the SPC5516EAVLQ66 MCU only in the operating temperature?
Enes
kralsemo06
Hi David,
What does "reserverd / optinial field" mean. Can you give a more detailed explanation?
Can "SPC5516EAVLQ66" be used as an alternative to "SPC5516EBMLQ66"?
Oguzhan,
davidtosenovjan
The difference is used revision (A or B). If you have valid NDA, I can send you presentation describing the difference.
Pay attention to section 'Non-Disclosure Agreement (NDA)':
https://www.nxp.com/support/support:SUPPORTHOME
davidtosenovjan
I am attaching part number decoder:
