Example MPC5644A TSENS Temperature calculation CW210
* Detailed Description:
* Example shows MCU's temperature measurement with the help of TSENS.
* Calibration constants for TSENS are read from TSENS registers and
* eQADC is set to measure Vbg and TSENS outputs. eQADC calibration is also done.
* Calculated internal temperature can be displayed on the Terminal.
* See results on PC terminal (19200, 8N1, None). You should see following text
* (with different values for sure)
*    fsys = 150MHz
*    TSENS temperature calculation
*    Calibration constants read from TSENS registers
*    T_LOW = 25
*    T_HIGH = 145
*    TSENS_CODE_T_LOW = 5441
*    TSENS_CODE_T_HIGH = 7305
*    VBG_CODE_T_LOW = 4010
*                 (TSENS_CODE_T*beta - TSENS_CODE_T_LOW)*(T_HIGH - T_LOW)
*    T = T_LOW - --------------------------------------------------------- [degC]
*                       (TSENS_CODE_T_HIGH - TSENS_CODE_T_LOW)
*    VBG_CODE_T (ch45)  = 3959 => beta = 1.01288
*    TSENS_CODE_T (ch128) = 5608
*    Temp = 31.80 degC
* Test HW:        XPC564AKIT208S and XPC564AKIT324S
* MCU:            SPC5644AMMG1,0M14X and SPC5644AMVZ1,0M14X
* Fsys:           150/132/120/12 MHz
* Debugger:       Lauterbach Trace32
*                 PeMicro USB-ML-PPCNEXUS
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: default
标签 (1)
附件
评论
ok!!!!!!!!!!!!!!!!!!!!!!!
%3CLINGO-SUB%20id%3D%22lingo-sub-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5644A%20TSENS%20%E6%B8%A9%E5%BA%A6%E8%AE%A1%E7%AE%97%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20%E7%A4%BA%E4%BE%8B%E5%B1%95%E7%A4%BA%E4%BA%86%E5%80%9F%E5%8A%A9%20TSENS%20%E8%BF%9B%E8%A1%8C%20MCU%20%E7%9A%84%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E*%20TSENS%20%E7%9A%84%E6%A0%A1%E5%87%86%E5%B8%B8%E6%95%B0%E4%BB%8E%20TSENS%20%E5%AF%84%E5%AD%98%E5%99%A8%E8%AF%BB%E5%8F%96%EF%BC%8C%E5%B9%B6%E4%B8%94%3C%2FP%3E%3CP%3E*%20eQADC%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%B5%8B%E9%87%8F%20Vbg%20%E5%92%8C%20TSENS%20%E8%BE%93%E5%87%BA%E3%80%82eQADC%20%E6%A0%A1%E5%87%86%E4%B9%9F%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E*%20%E8%AE%A1%E7%AE%97%E5%87%BA%E7%9A%84%E5%86%85%E9%83%A8%E6%B8%A9%E5%BA%A6%E5%8F%AF%E4%BB%A5%E6%98%BE%E7%A4%BA%E5%9C%A8%E7%BB%88%E7%AB%AF%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%9F%A5%E7%9C%8B%20PC%20%E7%BB%88%E7%AB%AF%E4%B8%8A%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8819200%E3%80%818N1%E3%80%81%E6%97%A0%EF%BC%89%E3%80%82%E6%82%A8%E5%BA%94%E8%AF%A5%E7%9C%8B%E5%88%B0%E4%BB%A5%E4%B8%8B%E6%96%87%E6%9C%AC%3C%2FP%3E%3CP%3E*%EF%BC%88%E8%82%AF%E5%AE%9A%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E5%80%BC%EF%BC%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%20%3D%20150MHz%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20TSENS%E6%B8%A9%E5%BA%A6%E8%AE%A1%E7%AE%97%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E4%BB%8E%20TSENS%20%E5%AF%84%E5%AD%98%E5%99%A8%E8%AF%BB%E5%8F%96%E6%A0%A1%E5%87%86%E5%B8%B8%E6%95%B0%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20T_LOW%20%3D%2025%3C%2FP%3E%3CP%3E*%20T_HIGH%20%3D%20145%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_LOW%20%3D%205441%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_HIGH%20%3D%207305%3C%2FP%3E%3CP%3E*%20VBG_CODE_T_LOW%20%3D%204010%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%EF%BC%88TSENS_CODE_T*beta-TSENS_CODE_T_LOW%EF%BC%89*%EF%BC%88T_HIGH-T_LOW%EF%BC%89%3C%2FP%3E%3CP%3E*%20T%20%3D%20T_LOW%20-%20---------------------------------------------------------%20%5B%E6%91%84%E6%B0%8F%E5%BA%A6%5D%3C%2FP%3E%3CP%3E*%20%EF%BC%88TSENS_CODE_T_%E9%AB%98%20-%20TSENS_CODE_T_%E4%BD%8E%EF%BC%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20VBG_CODE_T%20(ch45)%20%3D%203959%20%3D%26gt%3B%20beta%20%3D%201.01288%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T%20(%E9%80%9A%E9%81%93128)%20%3D%205608%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%B8%A9%E5%BA%A6%20%3D%2031.80%20%E6%91%84%E6%B0%8F%E5%BA%A6%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AXPC564AKIT208S%20%E5%92%8C%20XPC564AKIT324S%3C%2FP%3E%3CP%3E*%20MCU%EF%BC%9ASPC5644AMMG1%2C0M14X%20%E5%92%8C%20SPC5644AMVZ1%2C0M14X%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9A150%2F132%2F120%2F12%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9ARAM%E3%80%81internal_FLASH%3C%2FP%3E%3CP%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3C%2FP%3E%3CP%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%E9%BB%98%E8%AE%A4%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20%E7%A4%BA%E4%BE%8B%E5%B1%95%E7%A4%BA%E4%BA%86%E5%80%9F%E5%8A%A9%20TSENS%20%E8%BF%9B%E8%A1%8C%20MCU%20%E7%9A%84%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E*%20TSENS%20%E7%9A%84%E6%A0%A1%E5%87%86%E5%B8%B8%E6%95%B0%E4%BB%8E%20TSENS%20%E5%AF%84%E5%AD%98%E5%99%A8%E8%AF%BB%E5%8F%96%EF%BC%8C%E5%B9%B6%E4%B8%94%3C%2FP%3E%3CP%3E*%20eQADC%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%B5%8B%E9%87%8F%20Vbg%20%E5%92%8C%20TSENS%20%E8%BE%93%E5%87%BA%E3%80%82eQADC%20%E6%A0%A1%E5%87%86%E4%B9%9F%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E*%20%E8%AE%A1%E7%AE%97%E5%87%BA%E7%9A%84%E5%86%85%E9%83%A8%E6%B8%A9%E5%BA%A6%E5%8F%AF%E4%BB%A5%E6%98%BE%E7%A4%BA%E5%9C%A8%E7%BB%88%E7%AB%AF%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%9F%A5%E7%9C%8B%20PC%20%E7%BB%88%E7%AB%AF%E4%B8%8A%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8819200%E3%80%818N1%E3%80%81%E6%97%A0%EF%BC%89%E3%80%82%E6%82%A8%E5%BA%94%E8%AF%A5%E7%9C%8B%E5%88%B0%E4%BB%A5%E4%B8%8B%E6%96%87%E6%9C%AC%3C%2FP%3E%3CP%3E*%EF%BC%88%E8%82%AF%E5%AE%9A%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E5%80%BC%EF%BC%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%20%3D%20150MHz%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20TSENS%E6%B8%A9%E5%BA%A6%E8%AE%A1%E7%AE%97%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E4%BB%8E%20TSENS%20%E5%AF%84%E5%AD%98%E5%99%A8%E8%AF%BB%E5%8F%96%E6%A0%A1%E5%87%86%E5%B8%B8%E6%95%B0%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20T_LOW%20%3D%2025%3C%2FP%3E%3CP%3E*%20T_HIGH%20%3D%20145%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_LOW%20%3D%205441%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_HIGH%20%3D%207305%3C%2FP%3E%3CP%3E*%20VBG_CODE_T_LOW%20%3D%204010%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%EF%BC%88TSENS_CODE_T*beta-TSENS_CODE_T_LOW%EF%BC%89*%EF%BC%88T_HIGH-T_LOW%EF%BC%89%3C%2FP%3E%3CP%3E*%20T%20%3D%20T_LOW%20-%20---------------------------------------------------------%20%5B%E6%91%84%E6%B0%8F%E5%BA%A6%5D%3C%2FP%3E%3CP%3E*%20%EF%BC%88TSENS_CODE_T_%E9%AB%98%20-%20TSENS_CODE_T_%E4%BD%8E%EF%BC%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20VBG_CODE_T%20(ch45)%20%3D%203959%20%3D%26gt%3B%20beta%20%3D%201.01288%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T%20(%E9%80%9A%E9%81%93128)%20%3D%205608%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%B8%A9%E5%BA%A6%20%3D%2031.80%20%E6%91%84%E6%B0%8F%E5%BA%A6%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AXPC564AKIT208S%20%E5%92%8C%20XPC564AKIT324S%3C%2FP%3E%3CP%3E*%20MCU%EF%BC%9ASPC5644AMMG1%2C0M14X%20%E5%92%8C%20SPC5644AMVZ1%2C0M14X%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9A150%2F132%2F120%2F12%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9ARAM%E3%80%81internal_FLASH%3C%2FP%3E%3CP%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3C%2FP%3E%3CP%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%E9%BB%98%E8%AE%A4%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎04-22-2015 01:57 AM
更新人:
