Saving value to the flash memory on user input on MC56F8...
2,046 次查看
sm0khey
Hello! I want to save a value which is from user input to the flash memory. Since i am new to Embedded programming, can someone explain to me the steps and what code/library to use
3 回复数
2,014 次查看
xiangjun_rong
Can you tell us the part number you are using?
generally, we  provide the api function to erase/program flash, the api function is saved in flash and copied to program RAM and execute in program RAM.
In detail, if you use Processor Expert(PE), the PE generates the api function to erase/program flash. If the silicon does not support PE, we have example code to erase/program flash in application code.
Hope it can help you
XiangJun Rong
2,011 次查看
sm0khey
Hello! It's MC56F8257, i've tried the API IFlsh, but the processor just stops working
1,995 次查看
xiangjun_rong
Pls try to use the attached code and have a test.
XiangJun Rong
