Cannot use fprintf in MCUxpresso SDK
mjkimbravo
I am wanting to print contents to a file using the C function "fprintf()," but it does not work.
My device is QN9080 and I run some SDKs in MCUxpresso IDE. I set library/header to semihost config (already test every setting like Redlib, Newlib, NewlibNano in semihost). Some parts of my very simple code is below (send_data is a data which I want to write in .csv)
Here, .csv file is generated well, but code makes some errors at fprintf(); The error is...
Of course I include "stdio.h", "stdlib.h", and other kinds of headers. I also try to find a solution in "MCUXpresso IDE user guide.pdf" but it failed. I already found similar questions with me in NXP community, but those are not helpful for me.
Would you please help me?
Ricardo_Zamora
Hope you are doing well. I would recommend checking these posts:
Solved: semihosting fopen path - NXP Community
Solved: Re: Writing to a file (fprintf) in MCUXpresso IDE (11.3.1) - NXP Community
Hope this helps!
Ricardo
mjkimbravo
Thank you for your reply.
As I mentioned in my main post, of course I already have read the posts you inform. But those are not helpful to me. I think my problem is a different kind of errors (something like I cannot use fprintf() itself). Would you please see the picture I uploaded in my main post and consider my problem?
Why this kind of errors happen?:
Can't find a source file at "/opt/jenkins/workspace/Libraries_ElevenNine/Redlib/redlib_clib/armv7e-m_fpu/.../src/fpprintf.c
