I am using IMXRT1170 board with SDK 2.10.1. I am testing a web service client. My client, the 1170 EVK is able to communicate with sever over TCP, but not always. Inconsistently I am getting below error messages from LWIP stack. Please help me to find the root cause of these message.
"tcpip_thread invalid message"
"memp:malloc memp properly aligned"
hi jeremyzhou please find the details below
IDE - MCUXpresso
board - imxrt1170
code - custom code for web service communication. using SDK 2.10.1
testing setup - we have a custom protocol for webservice communication. It is based on the DPWS library. We have ported it for free RTOS. My EVK is the client. It is able to connect to server and do data exchange(in xml format) but not always. Inconsistently I am getting errors from tcpip thread.
Thanks for your reply.
From my experience, it's hard to draw a conclusion according to the above two messages, moreover, it happens on a customized demo code.
Whether you can share the captured ethernet network frame, may provide some insights into the issue.
TIC
I enable MEMP_OVERFLOW_CHECK and now I am getting below message from tcp_ip thread.
"detected mem underflow in TCP_PCB"
This happens after communicating 3 times with server. Each time we connects and disconnects the socket.
Kindly please help to solve.
Sorry for replying late.
I think I need more information, please introduce how to set up the testing environment to replicate the phenomenon and upload the related codes and tools.
TIC
TIC
To provide the fastest possible support, I was wondering if you can describe the testing environment to replicate the phenomenon, such as IDE, board, demo code, testing steps, etc,
TIC
