How to change the value of ${author} variable used in MCUXpresso
Badman
Now new project in C has
 Author      : $(author)
 Version     :
 Copyright   : $(copyright)
 Description : main definition
How to change he value of ${author} and how to add time create file ?
I want the new file to look like this:
 Author      : Badman
 Created on  : 06.07.2022
 Version     :
ErichStyger
Specialist I
You can edit and configure this with Code Templates, see
Badman
Thank you very much.
OK, I can replace $author with a constant. But how do I set the value of $author ?
ErichStyger
Specialist I
It is actually not ${author}, but ${user}:
Just wrote about it, see https://mcuoneclipse.com/2022/07/13/custom-user-with-c-c-code-templates/
I hope this helps,
Erich
