How can I Fix "source/DAC.o Error 126"
josesantacruz
  1. I´m using MCUXpresso IDE v10.0.2 [Build 411] [2017-07-11], when I build my project it results these problem, "source/DAC.o Error 126"
lpcxpresso_supp
Please do a clean of your project, then a build - then post the actual text from build log displayed in the Console View (as per section 14.11 - The Console View - of the MCUXpresso IDE v10.0.2 User Guide). Depending on how big this is, you might want to copy into a text file and attach it to this thread (but please don't post a photo of the console).
Please also confirm what MCU you are building your project for, whether you are using an SDK - and if so which one.
Also do you see this problem with standard examples for your MCU? Or is this only affecting your own project?
MCUXpresso IDE Support
Hello Jose,
Please show the console view and also describe  your project in detail , it is a demo project ?
SDK? How do you make it ...
TIC
ZhangJennie
Hi Jose
This space is for Community usage, I suggest you move this thread to MCUXpresso IDE  space. there are IDE support engineers monitoring IDE questions.
Jennie Zhang
