MCUXpresso Config Tools v4 Now Available
petrstruzka
We are pleased to announce that MCUXpresso Config Tools v4 are now available.
MCUXpresso Configuration Tools is a product with set of tools that help users of all levels with a Cortex-M-based MCU solution.
Features:
  • Available as Web and Desktop application
  • Kinetis SDK v2 support
  • Multicore support
  • Localized for English and Simplified Chinese
  • Mostly Connected: On-Demand device data download
  • Integrates with any compiler and IDE
Currently there are the following tools available:
  • Peripherals
  • Pins
  • Clocks
  • Project cloner
To download the installer for all platforms, please login to our download site via:
Please refer to MCUXpresso Config Tools documentation for installation and quick start guides.
For online version, login into MCUXpresso site:
Overview of Changes - version 4
  • Peripherals Tool added
  • Project Generator replaced by Project Cloner
  • Added ability to import configuration from existing MEX file (for selected tools)
  • If the MEX file is stored within toolchain project, the tool reports missing SDK component in that project, that are required by the tool
  • Open configuration command verifies that the configuration matches with sources detected from toolchain project
  • Added common Functions group toolbar across all tools
  • Added option to not generate YAML
  • Pins tool: multiselect in Routed pins view supported
  • Syntax coloring supported in Sources view
  • Export sources wizard simplified
  • Several bug fixed and performance improved
  • Quick start guide added
Community
