creation a docker on UBUNTU 20.04
YK
Hello everybody.
I downloaded a flexbuild for the board ls1028ardb. As I understood from a  document "Layerscape LS1028A BSP v0.2" it shall be either Ubuntu 18.04 system  or appropriated docker must be created.
My host machine has Ubuntu 20.04.6.  shall I create a docker as it explained in the document, because it is not Ubuntu 18.04 or I can use flex-builder directly without a docker?
Thanks a lot for any advise.
Bio_TICFSL
Yes you can. but some issue may arise since not compatibility of packages between 18.04 and 20.04 .
