LS1088ARDB/LS1088ARDB-PB - How to update U-Boot binary on SD card
This how-to topic is applicable only to LSDK 18.09 and older releases. For LSDK 18.12 and newer releases, refer LS1088ARDB-PB - How to deploy TF-A binaries on SD card.
Follow these steps to update U-Boot binary on the SD card.
Prerequisites
  • Ubuntu 18.04 64-bit should be installed on the Linux host machine for building LSDK 18.06 or LSDK 18.09 U-Boot binary.
Compiling U-Boot binary
Clone the u-boot repository.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/u-boot.git
  2. $ cd u-boot
  3. $ git checkout -b <new branch name> LSDK-<LSDK version>. For example, $ git checkout -b LSDK-18.09 LSDK-18.09
  4. $ export ARCH=arm64
  5. $ export CROSS_COMPILE=aarch64-linux-gnu-
  6. $ make distclean
  7. Execute appropriate defconfig file:
    • For LS1088ARDB: $ make ls1088ardb_sdcard_qspi_defconfig
    • For LS1088ARDB-PB: $ make ls1088ardb_pb_sdcard_qspi_defconfig
  8. If required, make changes to the U-Boot files.
  9. $ make
If the make command shows the error "*** Your GCC is older than 6.0 and is not supported", ensure that you are using Ubuntu 18.04 64-bit version for building LSDK 18.06 or LSDK 18.09 U-Boot binary.
The compiled U-Boot image, u-boot-with-spl.bin, is available at u-boot/.
SD card start block number for U-Boot binary
Image SD card start block number
U-Boot binary0x00800 = 2048
Refer the Flash layout for boot flow with PPA – LSDK 18.09 and older releases for a complete listing of the SD card start block numbers for all LSDK firmware images.
Programming U-Boot binary to SD card
  1. Plug the SD card into the Linux host.
  2. Run the following command on the Linux host:
    • $ sudo dd if=u-boot-with-spl.bin of=/dev/sdX bs=512 seek=2048 conv=fsync
      Use the command cat /proc/partitions to see a list of devices and their sizes to
      make sure that the correct device names have been chosen.
      The SDHC storage drive in the Linux PC is detected as /dev/ sdX, where X is a letter such as a, b, c. Make sure to choose the correct device name, because data on this device will be replaced.
      If your Linux host machine supports read/write SDHC card directly without an extra SDHC card reader device, the device name of SDHC card is typically mmcblk0.
  3. Remove the SD card from the Linux host machine.
  4. On the LS1088ARDB/LS1088ARDB-PB, ensure that the switches are set to boot the board from SD card.
    • For booting from SD card, SW1[1:8] + SW2[1] = 0010_0000_0
  5. Plug the SD card into the board and boot the board to Ubuntu.
If U-Boot does not find LSDK on the SD card, it will boot TinyDistro from lsdk_linux_arm64_ tiny.itb stored on the SD card.
コメント
Great guide, thank you !
%3CLINGO-SUB%20id%3D%22lingo-sub-1118025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1088ARDB%2FLS1088ARDB-PB%20-%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AEU-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%8F%E3%82%A6%E3%83%84%E3%83%BC%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81LSDK%2018.09%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82LSDK%2018.12%20%E4%BB%A5%E9%99%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8C%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342624%22%20target%3D%22_blank%22%3ELS1088ARDB-PB%20-%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%20TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FA%3E%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AEU-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-381646891%22%20id%3D%22toc-hId-381646891%22%20id%3D%22toc-hId-1297572210%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%3C%2FSPAN%3E%3C%2FH1%3E%3CUL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ELSDK%E2%80%AF18.06%20%E3%81%BE%E3%81%9F%E3%81%AF%20LSDK%E2%80%AF18.09%20%E3%81%AE%20U%E2%80%91Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Linux%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%20Ubuntu%E2%80%AF18.04%E2%80%AF64%E2%80%91bit%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425807572%22%20id%3D%22toc-hId--1425807572%22%20id%3D%22toc-hId--509882253%22%3EU%E2%80%91Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FH1%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Eu-boot%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%E2%80%AF%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Egit%20clone%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CA%20data-content-finding%3D%22Community%22%20style%3D%22color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20inherit%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Fu-boot.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Ecd%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Eu-boot%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20LSDK-.%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%80%8C%3C%2FSPAN%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%20LSDK-18.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20LSDK-18.09%20%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eexport%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20ARCH%3Darm64%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eexport%20CROSS_COMPILE%3D%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Eaarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Edistclean%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E9%81%A9%E5%88%87%E3%81%AA%20defconfig%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ELS1088ARDB%E3%81%AE%E5%A0%B4%E5%90%88%3A%24%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%20ls1088ardb_sdcard_qspi_defconfig%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ELS1088ARDB-PB%E3%81%AE%E5%A0%B4%E5%90%88%3A%24%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20make%20the%20ls1088ardb_pb_sdcard_qspi_defconfig%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81U-Boot%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%BD%9C%E3%82%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CPRE%20___default_attr%3D%22info%22%20_alert%3D%22info%22%20_modifiedtitle%3D%22true%22%20jivemacro%3D%22alert%22%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%3C%2FSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%22***%20Your%20GCC%20is%20older%20than%206.0%20and%20is%20not%20supported%22%3C%2FSPAN%3E%20%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81LSDK%E2%80%AF18.06%20%E3%81%BE%E3%81%9F%E3%81%AF%20LSDK%E2%80%AF18.09%20%E3%81%AE%20U%E2%80%91Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%20Ubuntu%E2%80%AF18.04%E2%80%AF64%E2%80%91bit%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%3C%2FPRE%3E%3C%2FPRE%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20U-Boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot-with-spl%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%AF%20%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061705261%22%20id%3D%22toc-hId-1061705261%22%20id%3D%22toc-hId-1977630580%22%3EU%E2%80%91Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E9%96%8B%E5%A7%8B%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FTH%3E%3CTH%3ESD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E9%96%8B%E5%A7%8B%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EU-Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E0x00800%20%3D%202048%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20LSDK%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E9%96%8B%E5%A7%8B%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%AA%E3%82%B9%E3%83%88%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22http%3A%2F%2Fwww.%2Fdocs%2FDOC-342787%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20underline%3B%22%20target%3D%22_blank%22%3EPPA%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%20%E2%80%93%20LSDK%2018.09%20%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FA%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3CH1%20id%3D%22toc-hId--745749202%22%20id%3D%22toc-hId--745749202%22%20id%3D%22toc-hId-170176117%22%3EU%E2%80%91Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FH1%3E%3COL%3E%3CLI%3ESD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%20Linux%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3ELinux%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CUL%20style%3D%22list-style-type%3A%20circle%3B%22%3E%3CLI%3E%24%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esudo%20dd%20if%3Du-boot-with-spl.bin%20of%3D%2Fdev%2FsdX%20bs%3D512%20seek%3D2048%20conv%3Dfsync%3C%2FSPAN%3E%3CPRE%20___default_attr%3D%22info%22%20_alert%3D%22info%22%20jivemacro%3D%22alert%22%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3Ecat%20%2Fproc%2Fpartitions%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%9D%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E4%B8%80%E8%A6%A7%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A3%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%90%8D%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%20PC%20%E3%81%AE%20SDHC%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AF%20%2Fdev%2FsdX%20%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82X%20%E3%81%AF%20a%E3%80%81b%E3%80%81c%20%E3%81%AA%E3%81%A9%E3%81%AE%E6%96%87%E5%AD%97%E3%81%A7%E3%81%99%E3%80%82%E5%BF%85%E3%81%9A%E6%AD%A3%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%90%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%AE%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AA%E3%81%97%E3%81%A7%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%82%92%E7%9B%B4%E6%8E%A5%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%90%8D%E3%81%AF%E9%80%9A%E5%B8%B8%20mmcblk0%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3C%2FPRE%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3ELinux%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8B%E3%82%89SD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3CLI%3ELS1088ARDB%2FLS1088ARDB-PB%20%E3%81%A7%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW1%5B1%3A8%5D%20%2B%20SW2%5B1%5D%20%3D%200010_0000_0%3C%2FSPAN%3E%26nbsp%3B%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92Ubuntu%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EU%E2%80%91Boot%20%E3%81%8C%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%20LSDK%20%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9F%20%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elsdk_linux_arm64_tiny.itb%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%8B%E3%82%89%20TinyDistro%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALS1088ARDB%20%2F%20LS1088ARDB-PB%20-%20SD%E3%82%AB%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AEU-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%82%AC%E3%82%A4%E3%83%89%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:38 AM
更新者:
