LS1088ARDB/LS1088ARDB-PB - How to update PBL/RCW binary in QSPI NOR flash
This how-to topic is applicable only for LSDK 18.09 and older releases.
For LSDK 18.12 and newer releases, refer LS1088ARDB-PB - How to deploy TF-A binaries in QSPI NOR flash.
Follow these steps to update the PBL/RCW binary in QSPI NOR flash.
qixis_reset boots the board from QSPI NOR flash0 and qixis_reset altbank boots the board from QSPI NOR flash1.
sf probe 0:1 means that the alternate bank will be written to. So, if the board boots from QSPI NOR flash0 and sf probe 0:1 is entered at the U-Boot prompt, the commands that follow will program QSPI NOR flash1.
Compiling PBL binary from RCW source file (optional)
If user already has a PBL binary, this step can be skipped.
Clone the rcw repository and compile the PBL binary.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/rcw
  2. $ cd rcw
  3. $ git checkout -b <new branch name> <LSDK tag>. For example, $ git checkout -b LSDK-18.09 LSDK-18.09
  4. $ cd ls1088ardb
  5. If required, make changes to the rcw files.
  6. $ make
The default PBL binary for QSPI NOR flash on LS1088ARDB/LS1088ARDB-PB, rcw_1600_qspi.bin, is available at rcw/ls1088ardb/FCQQQQQQQQ_PPP_H_0x1d_0x0d/.
See the rcw/ls1088ardb/README file for an explanation of the naming convention for the directories that contain the RCW source and binary files.
Flashing PBL binary to QSPI NOR flash
  1. Boot LS1088ARDB/LS1088ARDB-PB from QSPI. Ensure that the switches are set to boot the board from QSPI. For booting from QSPI, SW1[1:8] + SW2[1] = 0011_0001_X
  2. Boot from QSPI NOR flash0: => qixis_reset
For example:
For LS1088ARDB, in boot log, you’ll see:
Board: LS1088A-RDB, Board Arch: V1, Board version: C, boot from QSPI:0
For LS1088ARDB-PB, in boot log, you'll see:
Board: LS1088ARDB-PB, Board Arch: V1, Board version: A, boot from QSPI:0
PBL binary can be loaded to LS1088ARDB/LS1088ARDB-PB from a TFTP server or from a mass storage device (SD, USB, or SATA).
Option 1: Load image from a TFTP server
Set up Ethernet connection
When board boots up, U-Boot prints a list of enabled Ethernet interfaces.
DPMAC1@xgmii, DPMAC2@xgmii, DPMAC3@qsgmii, DPMAC4@qsgmii, DPMAC5@qsgmii, DPMAC6@qsgmii, DPMAC7@qsgmii, DPMAC8@qsgmii, DPMAC9@qsgmii, DPMAC10@qsgmii
  1. Set server IP address to the IP address of the host machine on which you have configured the TFTP server.
    => setenv serverip <ipaddress1>
  2. Set ethact and ethprime as the Ethernet interface connected to the TFTP server.
    See LS1088ARDB/LS1088RDB-PB Ethernet port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
    => setenv ethprime <name of interface connected to TFTP server>
    For example:
    => setenv ethprime DPMAC3@qsgmii
    => setenv ethact <name of interface connected to TFTP server>
    For example:
    => setenv ethact DPMAC3@qsgmii
  3. Set IP address of the board. You can set a static IP address or, if the board can connect to a dhcp server, you can use the dhcp command.
    Static IP address assignment:
    => setenv ipaddr <ipaddress2>
    => setenv netmask <subnet mask>
    Dynamic IP address assignment:
    => dhcp
  4. Save the settings. => saveenv
  5. Check the connection between the board and the TFTP server.
    => ping $serverip
    Using DPMAC3@qsgmii device
    host 192.168.1.1 is alive
Load PBL binary from the TFTP server
  1. Program QSPI NOR flash1: => sf probe 0:1
  2. TFTP PBL binary from the server to the DDR and write image to QSPI NOR flash1:
    1. => tftp 0xa0000000 <pbl binary>
    2. => print filesize
      filesize=b4
    3. => sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
      Address 0x0 is the location of PBL in QSPI NOR flash.  For the complete flash memory layout for the PPA boot flow, refer Flash layout for old boot flow with PPA.
  3. Boot from QSPI NOR flash1: => qixis_reset altbank
    Board: LS1088A-RDB, Board Arch: V1, Board version: C, boot from QSPI:1
    Board: LS1088ARDB-PB, Board Arch: V1, Board version: A, boot from QSPI:1
Ensure that SD card, USB flash drive, or SCSI hard disk installed with LSDK Ubuntu distribution is plugged into the board to boot the board to Ubuntu. If U-Boot does not find LSDK on a mass storage device, it will boot TinyDistro from lsdk_linux_arm64_ tiny.itb stored in QSPI NOR flash.
Option 2: Load image from partition on mass storage device (SD, USB, or SATA)
  1. Select mass storage device to use.
    => mmc rescan
    => mmc info
    Or
    => usb start
    => usb info
    Or
    => scsi scan
    => scsi info
  2. Optional – List files on the storage device.
    => ls mmc <device:partition>
    For example:
    => ls mmc 0:2
    Or
    => ls usb <device:partition>
    For example:
    => ls usb 0:1
    Or
    => ls scsi <device:partition>
    For example:
    => ls scsi 0:2
  3. Program QSPI NOR flash1: => sf probe 0:1
  4. Load PBL image from the storage device.
    => load mmc 0:2 a0000000 <image name>
    => print filesize
    For example:
    => load mmc 0:2 a0000000 rcw_1600_qspi.bin
    => print filesize
    filesize=b4
    Or
    => load usb 0:2 a0000000 <image name>
    => print filesize
    Or
    => load scsi 0:2 a0000000 <image name>
    => print filesize
  5. Program image to QSPI NOR flash: => sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
    Address 0x0 is the location of PBL binary in QSPI NOR flash.  Refer Flash layout for old boot flow with PPA for the complete flash memory layout for the PPA boot flow.
  6. Boot from QSPI NOR flash1: => qixis_reset altbank
标签 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1126768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1088ARDB%2FLS1088ARDB-PB%20-%20%E5%A6%82%E4%BD%95%E6%9B%B4%E6%96%B0%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%20PBL%2FRCW%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E6%9C%AC%E6%93%8D%E4%BD%9C%E6%96%B9%E6%B3%95%E4%B8%BB%E9%A2%98%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20LSDK%2018.09%20%E5%8F%8A%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20inherit%3B%22%3E%E5%AF%B9%E4%BA%8E%20LSDK%2018.12%20%E5%8F%8A%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342648%22%20target%3D%22_blank%22%3ELS1088ARDB-PB%20-%20%E5%A6%82%E4%BD%95%E5%9C%A8%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%E9%83%A8%E7%BD%B2%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FA%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%9B%B4%E6%96%B0%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%3CSPAN%20lang%3D%22EN-US%22%3EPBL%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22EN-US%22%3E%2FRCW%3C%2FSPAN%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CDIV%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eqixis_reset%3C%2FSPAN%3E%E4%BB%8E%20QSPI%20NOR%20flash0%20%E5%90%AF%E5%8A%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%8C%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eqixis_reset%20altbank%3C%2FSPAN%3E%E4%BB%8E%20QSPI%20NOR%20flash1%20%E5%90%AF%E5%8A%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CDIV%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20probe%200%3A1%3C%2FSPAN%3E%E8%A1%A8%E7%A4%BA%E5%B0%86%E5%86%99%E5%85%A5%E5%A4%87%E7%94%A8%E9%93%B6%E8%A1%8C%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%BB%8E%20QSPI%20NOR%20flash0%20%E5%92%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20%E6%8E%A2%E9%92%88%200%3A1%20%E5%90%AF%E5%8A%A8%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E5%9C%A8%20U-Boot%20%E6%8F%90%E7%A4%BA%E7%AC%A6%E4%B8%8B%E8%BE%93%E5%85%A5%E5%90%8E%EF%BC%8C%E5%90%8E%E9%9D%A2%E7%9A%84%E5%91%BD%E4%BB%A4%E5%B0%86%E5%AF%B9%20QSPI%20NOR%20flash1%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382517684%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2026px%3B%22%20id%3D%22toc-hId-382517684%22%20id%3D%22toc-hId-1303267250%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E7%BC%96%E8%AF%91%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%9D%A5%E8%87%AA%20RCW%20%E6%BA%90%E6%96%87%E4%BB%B6%EF%BC%88%E5%8F%AF%E9%80%89%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%E5%A6%82%E6%9E%9C%E7%94%A8%E6%88%B7%E5%B7%B2%E7%BB%8F%E6%9C%89%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E8%B7%B3%E8%BF%87%E6%AD%A4%E6%AD%A5%E9%AA%A4%E3%80%82%3CSPAN%20data-ccp-props%3D%22%7B%22%20201341983%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%85%8B%E9%9A%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%3C%2FSPAN%3E%E5%AD%98%E5%82%A8%E5%BA%93%E5%B9%B6%E7%BC%96%E8%AF%91%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3CSPAN%20data-ccp-props%3D%22%7B%22%20201341983%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%3CSPAN%3E%24%20git%20clone%3C%2FSPAN%3E%20%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Frcw%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%24%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Ecd%20rcw%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%3CLSDK%20tag%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%20%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FSPAN%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%20-b%20LSDK-18.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20LSDK-18.09%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20cd%20ls1088ardb%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E6%9B%B4%E6%94%B9%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20make%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22margin%3A%200px%3B%20padding%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20color%3A%20windowtext%3B%20text-indent%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200px%3B%20padding%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20color%3A%20windowtext%3B%20text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3ELS1088ARDB%2F%20LS1088ARDB-PB%3C%2FSPAN%3E%20%E4%B8%8A%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E7%9A%84%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%20%E9%BB%98%E8%AE%A4%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%20%3CSPAN%3E%3C%2FSPAN%3E%EF%BC%8C%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20rcw_1600_qspi.bin%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E5%8F%AF%E5%9C%A8%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%20rcw%2Fls1088ardb%3C%2FSPAN%3E%20%2F%3CSPAN%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%20FCQQQQQQQQ_PPP_H_0x1d_0x0d%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%20style%3D%22margin%3A%200px%3B%20padding%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20color%3A%20windowtext%3B%20text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%9F%A5%E7%9C%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20border-bottom%3A%201px%20solid%20transparent%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2Fls1088ardb%2FREADME%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E8%A7%A3%E9%87%8A%E4%BA%86%E5%8C%85%E5%90%AB%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%E9%81%A5%E6%8E%A7%E6%AD%A6%E5%99%A8%E7%AB%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%9D%A5%E6%BA%90%E5%92%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20padding%3A%200px%3B%20margin%3A%200px%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E9%97%AA%E7%83%81%E7%9A%84%20PBL%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%88%B0%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EQSPI%20NOR%E9%97%AA%E5%AD%98%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E4%BB%8E%20QSPI%20%E5%90%AF%E5%8A%A8%20LS1088ARDB%2FLS1088ARDB-PB%E3%80%82%E7%A1%AE%E4%BF%9D%E5%BC%80%E5%85%B3%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BB%8E%20QSPI%20%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E4%BB%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EQSPI%E6%8E%A5%E5%8F%A3%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW1%5B1%3A8%5D%20%2B%20SW2%5B1%5D%20%3D%200011_0001_X%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E4%BB%8E%20QSPI%20NOR%20%E5%90%AF%E5%8A%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eflash0%3A%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20qixis_reset%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3CSTRONG%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS1088ARDB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1088A-RDB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AC%EF%BC%8C%E4%BB%8E%20QSPI%3A0%20%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS1088ARDB-PB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1088ARDB-PB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AA%EF%BC%8C%E4%BB%8E%20QSPI%3A0%20%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3EPBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%8F%AF%E4%BB%A5%E4%BB%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%88%96%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%EF%BC%88SD%E3%80%81USB%20%E6%88%96%20SATA%EF%BC%89%E5%8A%A0%E8%BD%BD%E5%88%B0%20LS1088ARDB%2FLS1088ARDB-PB%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1073079158%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId-1073079158%22%20id%3D%22toc-hId-1993828724%22%3E%E9%80%89%E9%A1%B9%201%EF%BC%9A%E4%BB%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%8A%A0%E8%BD%BD%E5%9B%BE%E5%83%8F%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1763640632%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20bold%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId-1763640632%22%20id%3D%22toc-hId--1610577098%22%3E%E8%AE%BE%E7%BD%AE%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%BF%9E%E6%8E%A5%3C%2FH3%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8CU-Boot%20%E4%BC%9A%E6%89%93%E5%8D%B0%E5%87%BA%E5%B7%B2%E5%90%AF%E7%94%A8%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E5%88%97%E8%A1%A8%E3%80%82%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EDPMAC1%40xgmii%2C%20DPMAC2%40xgmii%2C%20DPMAC3%40qsgmii%2C%20DPMAC4%40qsgmii%2C%20DPMAC5%40qsgmii%2C%20DPMAC6%40qsgmii%2C%20DPMAC7%40qsgmii%2C%20DPMAC8%40qsgmii%2C%20DPMAC9%40qsgmii%2C%20DPMAC10%40qsgmii%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3C%2FP%3E%3COL%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%3E%E5%B0%86%E6%9C%8D%E5%8A%A1%E5%99%A8%20IP%20%E5%9C%B0%E5%9D%80%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%82%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%E3%80%82%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20serverip%20%3CIPADDRESS1%3E%3C%2FIPADDRESS1%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CP%3E%E5%B0%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethact%3C%2FSPAN%3E%E5%92%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethprime%3C%2FSPAN%3E%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%BF%9E%E6%8E%A5%E5%88%B0%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E7%9C%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-341964%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3ELS1088ARDB%2FLS1088RDB-PB%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%E6%98%A0%E5%B0%84%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%94%A8%E4%BA%8E%E5%B0%86%E6%9C%BA%E7%AE%B1%E5%89%8D%E9%9D%A2%E6%9D%BF%E4%B8%8A%E6%98%BE%E7%A4%BA%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%E5%90%8D%E7%A7%B0%E4%B8%8E%20U-Boot%20%E5%92%8C%20Linux%20%E4%B8%AD%E7%9A%84%E7%AB%AF%E5%8F%A3%E5%90%8D%E7%A7%B0%E8%BF%9B%E8%A1%8C%E6%98%A0%E5%B0%84%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethprime%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethprime%20DPMAC3%40qsgmii%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethact%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%20connected%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethact%20DPMAC3%40qsgmii%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E8%AE%BE%E7%BD%AE%E6%9D%BF%E5%AD%90%E7%9A%84IP%E5%9C%B0%E5%9D%80%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E6%88%96%E8%80%85%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%BB%E6%9D%BF%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%20dhcp%20%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Edhcp%3C%2FSPAN%3E%E5%91%BD%E4%BB%A4%E3%80%82%3CP%3E%E9%9D%99%E6%80%81IP%E5%9C%B0%E5%9D%80%E5%88%86%E9%85%8D%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%3E%20%3D%26gt%3B%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20ipaddr%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3D%26gt%3B%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20setenv%20netmask%3CSUBNET%20mask%3D%22%22%3E%3C%2FSUBNET%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8A%A8%E6%80%81IP%E5%9C%B0%E5%9D%80%E5%88%86%E9%85%8D%EF%BC%9A%3CBR%20%2F%3E%20%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EDHCP%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E4%BF%9D%E5%AD%98%E8%AE%BE%E7%BD%AE%E3%80%82%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%BF%9D%E5%AD%98%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E6%A3%80%E6%9F%A5%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B9%8B%E9%97%B4%E7%9A%84%E8%BF%9E%E6%8E%A5%E3%80%82%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eping%20%24serverip%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%BD%BF%E7%94%A8DPMAC3%40qsgmii%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%200in%200in%20.0001pt%20.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9C%BA%20192.168.1.1%20%E6%98%AF%E6%B4%BB%E8%B7%83%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId--43813831%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20bold%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId--43813831%22%20id%3D%22toc-hId-876935735%22%3E%E4%BB%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%8A%A0%E8%BD%BD%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FH3%3E%3COL%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E7%BC%96%E7%A8%8B%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%201%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20sf%20probe%200%3A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ETFTP%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22EN-US%22%3EPBL%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E4%BB%8E%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%BC%A0%E8%BE%93%E5%88%B0%20DDR%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22EN-US%22%3E%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%9B%BE%E5%83%8F%E5%86%99%E5%85%A5%20QSPI%20NOR%20flash1%3C%2FSPAN%3E%20%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CBR%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%20%2F%3E%3C%2FSPAN%3E%3COL%20style%3D%22list-style-type%3A%20lower-alpha%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3B%3CSPAN%20lang%3D%22EN-US%22%3Etftp%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%26nbsp%3B0x%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3Ea%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E0000000%E2%80%AF%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3Epbl%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3Ebinary%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%26gt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E6%89%93%E5%8D%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efilesize%3Db4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20sf%20%E6%93%A6%E9%99%A4%200x0%20%2B%24filesize%20%26amp%3B%26amp%3B%20sf%20%E5%86%99%E5%85%A5%200xa0000000%200x0%20%24filesize%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E5%9C%B0%E5%9D%80%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E0x0%3C%2FSPAN%3E%E6%98%AF%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%20PBL%20%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3CSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E6%9C%89%E5%85%B3%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3EPPA%20%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%E5%AE%8C%E6%95%B4%E9%97%AA%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%8C%E8%AF%B7%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E5%8F%82%E9%98%85%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342787%22%20target%3D%22_blank%22%3E%E6%97%A7%E7%89%88%20PPA%20%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%E9%97%AA%E5%AD%98%E5%B8%83%E5%B1%80%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E4%BB%8E%20QSPI%20NOR%20flash1%20%E5%90%AF%E5%8A%A8%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20qixis_reset%20altbank%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS1088ARDB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1088A-RDB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AC%EF%BC%8C%E4%BB%8E%20QSPI%20%E5%90%AF%E5%8A%A8%EF%BC%9A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS1088ARDB-PB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1088ARDB-PB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AA%EF%BC%8C%E4%BB%8E%20QSPI%20%E5%90%AF%E5%8A%A8%EF%BC%9A1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%E7%A1%AE%E4%BF%9D%E5%AE%89%E8%A3%85%E4%BA%86%20LSDK%20Ubuntu%20%E5%8F%91%E8%A1%8C%E7%89%88%E7%9A%84%20SD%20%E5%8D%A1%E3%80%81USB%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%88%96%20SCSI%20%E7%A1%AC%E7%9B%98%E6%8F%92%E5%85%A5%E4%B8%BB%E6%9D%BF%EF%BC%8C%E4%BB%A5%E5%B0%86%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E5%88%B0%20Ubuntu%E3%80%82%E5%A6%82%E6%9E%9C%20U-Boot%20%E5%9C%A8%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%89%BE%E4%B8%8D%E5%88%B0%20LSDK%EF%BC%8C%E5%AE%83%E5%B0%86%E4%BB%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elsdk_linux_arm64_tiny.itb%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%AD%98%E5%82%A8%E5%9C%A8%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%22%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--54316935%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId--54316935%22%20id%3D%22toc-hId-866432631%22%3E%E9%80%89%E9%A1%B9%E4%BA%8C%EF%BC%9A%E4%BB%8E%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%EF%BC%88SD%20%E5%8D%A1%E3%80%81USB%20%E8%AE%BE%E5%A4%87%E6%88%96%20SATA%20%E7%A1%AC%E7%9B%98%EF%BC%89%E7%9A%84%E5%88%86%E5%8C%BA%E5%8A%A0%E8%BD%BD%E5%9B%BE%E5%83%8F%3C%2FH2%3E%3COL%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20400%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E9%80%89%E6%8B%A9%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FSPAN%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20rescan%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20start%3C%2FSPAN%3E%0A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20scan%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20info%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3E%E5%8F%AF%E9%80%89%E2%80%94%E2%80%94%E5%88%97%E5%87%BA%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%200%3A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E7%BC%96%E7%A8%8B%20%3CSPAN%3EQSPI%20NOR%20flash1%3C%2FSPAN%3E%3A%26nbsp%3B%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsf%20probe%200%3A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BB%8E%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E5%8A%A0%E8%BD%BD%20PBL%20%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%20a0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E5%8A%A0%E8%BD%BD%20mmc%200%3A2%20a0000000%20rcw_1600_qspi.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E6%89%93%E5%8D%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efilesize%3Db4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%E6%88%96%E8%80%85%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20usb%200%3A2%20a0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%E6%88%96%E8%80%85%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20scsi%200%3A2%20a0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%3E%E5%B0%86%E5%9B%BE%E5%83%8F%E7%BC%96%E7%A8%8B%3C%2FSPAN%3E%3CSPAN%3E%E5%88%B0%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%EF%BC%9A%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20erasure%200x0%20%2B%24filesize%20%26amp%3B%26amp%3B%20sf%20write%200xa0000000%200x0%20%24filesize%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E5%9C%B0%E5%9D%80%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%200x0%3C%2FSPAN%3E%20%E6%98%AF%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%E8%AF%B7%E5%8F%82%E9%98%85%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%E5%B8%A6%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%20PPA%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342787%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3E%E7%9A%84%E6%97%A7%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%E9%97%AA%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%8C%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%E4%BA%86%E8%A7%A3%20PPA%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%20%E5%AE%8C%E6%95%B4%E9%97%AA%E5%AD%98%E5%B8%83%E5%B1%80%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E4%BB%8E%20QSPI%20NOR%20flash1%20%E5%90%AF%E5%8A%A8%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20qixis_reset%20altbank%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS1088ARDB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1088A-RDB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AC%EF%BC%8C%E4%BB%8E%20QSPI%20%E5%90%AF%E5%8A%A8%EF%BC%9A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS1088ARDB-PB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1088ARDB-PB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AA%EF%BC%8C%E4%BB%8E%20QSPI%20%E5%90%AF%E5%8A%A8%EF%BC%9A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200px%3B%22%3E%E7%A1%AE%E4%BF%9D%E5%AE%89%E8%A3%85%E4%BA%86%20LSDK%20Ubuntu%20%E5%8F%91%E8%A1%8C%E7%89%88%E7%9A%84%20SD%20%E5%8D%A1%E3%80%81USB%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%88%96%20SCSI%20%E7%A1%AC%E7%9B%98%E6%8F%92%E5%85%A5%E4%B8%BB%E6%9D%BF%EF%BC%8C%E4%BB%A5%E5%B0%86%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E5%88%B0%20Ubuntu%E3%80%82%E5%A6%82%E6%9E%9C%20U-Boot%20%E5%9C%A8%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%89%BE%E4%B8%8D%E5%88%B0%20LSDK%EF%BC%8C%E5%AE%83%E5%B0%86%E4%BB%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elsdk_linux_arm64_tiny.itb%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%AD%98%E5%82%A8%E5%9C%A8%20QSPI%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1126768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E8%AE%BE%E5%A4%87%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎09-10-2020 03:10 AM
更新人:
