Content originally posted in LPCWare by Rob65 on Wed Dec 28 15:19:34 MST 2011
Quote: dragilla
Sorry, but this is really confusing me...
Both Zero and I have pointed you to the board schematics, data sheet and user manual.
I suggest you read those and try to figure out what happens.
Zero already answered your questions.
I assume you did connect the lpc1769 module to your PC and you did try to run a few sample programs. What happened? Did it work, was the LED flashing when you downloaded Blinky? And did it work even though you did not supply a Vbat? And did you see that both the data sheet or user manual mentions the Vbat pin and what to do with it (yes - it's in there, I read it but just don't remember which of the two documents it was).
You should be able to answer all your questions your self by checking the documents. If you are not able to read the schematics or understand what to do then maybe, just maybe, you are better of with a complete solution like and RDB1768 or an Embedded Artists Base Board.
Rob
