cd /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin && ./dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D LPCXpressoWIN.enc && ./crt_emu_cm3_nxp -info-target -wire=winusb && ./crt_emu_cm3_nxp -g -4 -wire=winusb -plpc1769 -flash-load-exec=/my-path/product-internal-flash.elf |
+ cd /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin + ./dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D LPCXpressoWIN.enc dfu-util - (C) 2005-2008 by Weston Schmidt, Harald Welte and OpenMoko Inc. This program is Free Software and has ABSOLUTELY NO WARRANTY Code Red Technologies Build : 03:46:35, Nov 21 2012 dfu-util currently only supportS DFU version 1.0 Opening DFU USB device... ID 0471:df55 Claiming USB DFU Runtime Interface... Determining device status: state = dfuIDLE, status = 0 WARNING: Runtime device already in DFU state ?!? Found Runtime: [0x0471:0xdf55] devnum=8, cfg=0, intf=0, alt=0, name="UNDEFINED" Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing bytes_per_hash=583 Copying data from PC to DFU device Starting download: [##################################################] finished! state(8) = dfuMANIFEST-WAIT-RESET, status(0) = No error condition is present Done! can't detach: Broken pipe Resetting USB to switch back to runtime mode error resetting after download: Result too large + ./crt_emu_cm3_nxp -info-target -wire=winusb Ni: LPCXpresso Debug Driver v7.0 (Mar 26 2014 18:32:42 - crt_emu_cm3_nxp build 1243) Nc: Looked for vendor directory XML file in /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin/nxp_directory.xml Nc: Found generic directory XML file in /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin/crt_directory.xml |
./dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D LPCXpressoWIN.enc && sleep 2 && ./crt_emu_cm3_nxp -flash-load-exec "/mypath/product-internal-flash.elf" -g -2 -vendor=NXP -pLPC1769 -wire=winUSB -s250 -flash-driver=LPC175x_6x_512.cfx |
cd /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin && ./dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D LPCXpressoWIN.enc && sleep 2 && ./crt_emu_cm3_nxp -flash-load-exec "/mypath/zPRODUCTS/product-internal-flash.elf" -g -2 -vendor=NXP -pLPC1769 -wire=winUSB -s250 -flash-driver=LPC175x_6x_512.cfx |
crt_emu_cm3_nxp -flash-load-exec "/myPath/product-internal-flash.elf" -g -2 -vendor=NXP -pLPC1769 -wire=winUSB -s250 -flash-driver=LPC175x_6x_512.cfx |
cd /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin && ./dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D LPCXpressoWIN.enc && ./crt_emu_cm3_nxp -flash-load-exec "/mypath/zPRODUCTS/product-internal-flash.elf" -g -2 -vendor=NXP -pLPC1769 -wire=winUSB -s250 -flash-driver=LPC175x_6x_512.cfx |
+ cd /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin + ./dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D LPCXpressoWIN.enc dfu-util - (C) 2005-2008 by Weston Schmidt, Harald Welte and OpenMoko Inc. This program is Free Software and has ABSOLUTELY NO WARRANTY Code Red Technologies Build : 03:46:35, Nov 21 2012 dfu-util currently only supportS DFU version 1.0 Opening DFU USB device... ID 0471:df55 Claiming USB DFU Runtime Interface... Determining device status: state = dfuIDLE, status = 0 WARNING: Runtime device already in DFU state ?!? Found Runtime: [0x0471:0xdf55] devnum=8, cfg=0, intf=0, alt=0, name="UNDEFINED" Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing bytes_per_hash=583 Copying data from PC to DFU device Starting download: [##################################################] finished! state(8) = dfuMANIFEST-WAIT-RESET, status(0) = No error condition is present Done! can't detach: Broken pipe Resetting USB to switch back to runtime mode error resetting after download: Result too large + ./crt_emu_cm3_nxp -flash-load-exec /myPath/zPRODUCTS/product-internal-flash.elf -g -2 -vendor=NXP -pLPC1769 -wire=winUSB -s250 -flash-driver=LPC175x_6x_512.cfx Ni: LPCXpresso Debug Driver v7.0 (Mar 26 2014 18:32:42 - crt_emu_cm3_nxp build 1243) Pc: ( 0) Reading remote configuration Nc: Looked for chip XML file in /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin/LPC1769.xml Nc: Looked for vendor directory XML file in /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin/nxp_directory.xml Nc: Found generic directory XML file in /Applications/lpcxpresso_7.1.1_125/lpcxpresso/bin/crt_directory.xml Pc: ( 5) Remote configuration complete Ed:02: Failed on connect: Ee(05). No matching emulator found - make sure power is on and not in use already. Et:31: No connection to emulator device Pc: (100) Target Connection Failed |
