USB HID loss of data
2,595件の閲覧回数
adb
Hello, I'm trying to send 16MB of data in 512 byte packets using USB0 HID. My program is based around the HID_generic example. The LPC4353 enumerates OK and I am able to successfully send 20 * 512 bytes of data to my computer but whenever I try to send larger quantities of data, up to 40% of my data gets lost.
Has anyone else experienced similar issues? Thanks in advance for your inputs.
Alan
4 返答(返信)
2,387件の閲覧回数
jeremyzhou
the opportunity to serve you.
I was wondering if you can introduce the steps of replicating this phenomenon, as it can help me to work it out.
I'm looking forward to your reply.
TIC
2,387件の閲覧回数
adb
Hi Jeremy,
Thank you for your email. My problem appears to be with my pc sub test program. I was able to get a c# program from Jan Axelson's website and was able to transfer all the expected data fron my microcontroller.
Alan
Sent from my Xperia™ smartphone
2,387件の閲覧回数
adb
Hi Jeremy,
I do have another question. In my program's current form, I have got a 1 ms delay between sending each 512 byte packet. With my C# program mentioned above, I'm able to receive all my data. However if this 1 ms delay is removed, I don't.
In hid_desc.c my bInterval variable has been set to 1ms. I thought the USB stack wouldn't allow data to go out until it was ready.
Thanks in advance for your comments,
Alan
2,387件の閲覧回数
jeremyzhou
Hi adb,
I've updated my reply of Case: 00164160, please checking it.
TIC
