not getting accurate reading of current on o/p sigma delta channel of MKM34Z256VLQ7
ravindrabalsara
hello sir,
We are facing issue with SIGMA DELTA  ADC.of MKM34Z256VLQ7 current{A} parameter measurment for genset application
Now at input side our voltage range is 0-500mV. (AC voltage)
We as of now we have taken average of the readings and we are getting readings but the values are much more varying with the same input value .
So we can't able to handle it .
Please help with the same problem
see the attached schematic for your reference.
xiangjun_rong
Hi, Ravindra,
Firstly, psl refer to the data sheet of KM34, the common mode voltage is from 0V to 0.8V. Your input common mode voltage is Vref/2 from your schematics, does it meets the input common mode voltage requirement?
Secondly, the AFE define the spec SINAD spec, this is the SINAD formula:
SINAD=6.02*ENOB+1.76
The SINAD spec is 80 with the condition:
Normal Mode
• fIN=50 Hz; common mode=0
V, Vpp= 500 mV (diff.)
V, Vpp= 500 mV (full range
se.)
it means that the ENOB is about 13 bits, for a 24 bits AFE data register, the low 10 bits may vary for the same input DC voltage.
Hope it can help you
XiangJun Rong
ravindrabalsara
Hello sir,
Till we are getting lot of variation in current measurements,in application
noteDRM162 mentioned connection for current transformer,how make connection
by using shunt resistors.is there need to change something.please guide.or
di you have any reference code to measure the current by using shunt
resistors in sigma Delta channel.
ravindrabalsara
thanks sir for your support .we are working on your suggestions,below i have mentioned my code ,please go through it once.
please let me know if anything need to be change in software code .
 unsigned int Cal_YPH_Current_GEN(int display)//channel @ 0U
         unsigned short  DD0=0, DD1=0, DD2=0, DD3=0;
         uint32_t  CIN_YPH1=0;
         /* Check conversion complete */
                                 //    if ((kAFE_Channel1ConversionCompleteFlag & AFE_GetChannelStatusFlags(DEMO_AFE_BASEADDR)))
                                         g_result1 = (int32_t)AFE_GetChannelConversionValue(DEMO_AFE_BASEADDR, DEMO_AFE_SECOND_CHANNEL);
                                         /* Set conversion done flag */
                                         g_bAfeSecondChannelConvDone = true;
       //  AFE_DoSoftwareTriggerChannel(DEMO_AFE_BASEADDR,kAFE_Channel1Trigger);
         /* Read channel 2 result conversion */
                        while (!g_bAfeSecondChannelConvDone)
                        g_bAfeSecondChannelConvDone = false;
//                        if(g_result1<0){
//                                       g_result1=0;
//                                       CIN_YPH= g_result1;
                       // printf("Second Channel value: %d\r\n\r\n", g_result1);
//         CIN_YPH=(g_result1*CT_Ratio)/10000;
                                       if(g_result1>0)
                                           CIN_YPH= g_result1;
                                       CIN_YPH= ( CIN_YPH*50)/(1000*read_ct_ratio);//read ct ration in s
                                       for (uint32_t l=0; l < 5; l++)
                                           CIN_YPH1=   CIN_YPH1+ CIN_YPH;
                                       CIN_YPH1 =  CIN_YPH1/5;
         printf("\r\n CIN_YPH is %d.\r\n",CIN_YPH1);
xiangjun_rong
Hi, Ravindra,
I suppose that your code is incorrect, I modify the code partly, pls check it.
XiangJun Rong
 //start to convert
         /* waiting for  conversion complete */
                                    while(!(kAFE_Channel1ConversionCompleteFlag & AFE_GetChannelStatusFlags(DEMO_AFE_BASEADDR))) {}
//reading sample after conversion is complete
//                        if(g_result1<0){
//                                       g_result1=0;
                                       if(g_result1>0)
                                           CIN_YPH= g_result1;
