Updating Bootloader of FRDM K22F OpenSDA MCU
bipin7301
Due to windows 10 issue bootloader of my FRDM K22F OpenSDA MCU corrupted. I have downloaded the binary file of latest OpenSDA bootloader and I have ULink 2 device to update the firmware.
Please suggest some utility to update the firmware directly to board. I don't have Keil IDE.
BlackNight
I don't have a ULink2, so cannot help you here.
But you can get a Segger J-Link EDU for $20. It comes with a flasher utility which you can use to program the binary.
Or get a LPC-Link2 ($20) and you can use the Flasher Utility in MCUXpresso IDE.
See Using Eclipse to Program Binary Files to an Embedded Target | MCU on Eclipse
I hope this helps,
Erich
