K60 32.768k crystal
K60 32.768k crystal
LJF111
32.768k crystal - Level of Drive:0.1uW Typ, 0.5uW Max.
Add series resistors?How much resistance?
Tags (3)
vicentegomez
Hi Jun
Normally this value depend on the mode that you want to run , if you want to run in low frequency high gain mode we recommend 200 k, but if you want to run in low frequency low power we do not have any specific value,
I also recomend you the application note AN3208
Vicente
