How use DSP in Kinetis K40X256 MCU?
3,335 次查看
Magnetron
How can I use DSP in Kinetis K40 MCU?
1,721 次查看
anthony_huereca
All the DSP instructions and documentation can be found on the ARM website.
Here is the latest reference manual for the M4 that has the DSP instructions with cycle times: http://infocenter.arm.com/help/topic/com.arm.doc.ddi0439c/DDI0439C_cortex_m4_r0p1_trm.pdf
And the assembly instructions are described in detail in this document: http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/DUI0553A_cortex_m4_dgug.pdf
You can also find the ARM CMSIS (Cortex Microcontroller Software Interface Standard) DSP 2.0 Library at http://www.onarm.com/
Anthony
1,722 次查看
anthony_huereca
Anthony
