Can't connect to FRDM-KE15Z
1,543件の閲覧回数
Frotz
I'm having trouble with my FRDM-KE15Z. After three days of nothing but smooth and easy work trying out this nifty board, today it doesn't want to connect properly. The drive appears on my Mac, the green and amber LED's come on and the red LED flickers during the resets, but no downloading. Opening a terminal to the board works and the amber LED flashes when I type, but there's no program in the MCU to do anything as it has been erased by this point in the process. My LPCXpresso845MAX, which also arrived on Monday works perfectly, though. (FYI: I'm using one board at a time.) I've pasted in the logs below. Could you help, please?
Thank you very much,
Andre.
————————————— RedlinkServer —————————————
[Started server]
[Connected on port 3025]
redlink> ProbeList
Index = 1
Manufacturer = ARM
Description = DAPLink CMSIS-DAP
Serial Number = 0213000036934e45003c40149f3500130e61000097969900
VID:PID = 0D28:0204
Path = USB_0d28_0204_fa140000_ff00
redlink> ProbeStatus
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireInitialized = FALSE
WireProtocol = JTAG
CoresConfigured = FALSE
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
Probe Type = CMSIS-DAP
Probe Reference Count = 0
redlink> ProbeList
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireProtocol = JTAG
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
redlink> ProbeIsOpen 1
FALSE
redlink> ProbeOpenByIndex 1
Probe Handle 1 Open
redlink> WireIsConnected 1
FALSE
redlink> WireSwdConnect 1
DpID = 0BC11477
redlink> CoresConfigured 1
FALSE
redlink> CoreConfig 1
Number of CORES/TAPs = 1, Fully recognized: True
Index = 1
Manufacturer = ARM
VID:PID = 0D28:0204
IsOpen = FALSE
WireProtocol = JTAG
PacketSize = 64
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
redlink> quit
[Closed]
————————————— GUI Flash Tool Console —————————————
============= END SCRIPT =============================
Probe Firmware: DAPLink CMSIS-DAP (ARM)
Serial Number:  0213000036934e45003c40149f3500130e61000097969900
VID:PID:  0D28:0204
USB Path: USB_0d28_0204_fd132100_ff00
Using memory from core 0 after searching for a good core
connection failed - Nn(05). Wire ACK Fault in DAP access.. Retrying
Failed on connect: Nn(05). Wire ACK Fault in DAP access
Connected&Reset. Was: NotConnected. DpID: 40000000. CpuID: 00000000. Info: <None>
Last stub error 0: OK
Last sticky error: 0x0 AIndex: 0
Debug bus selected: MemAp 0
DAP Speed test unexecuted or failed
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
(100) Target Connection Failed
error closing down debug session - Nn(05). Wire ACK Fault in DAP access
Unable to perform operation!
Command failed with exit code 1
————————————— GDB Traces —————————————
052,079 (gdb)
052,080 15-interpreter-exec console "set mi-async"
052,081 =cmd-param-changed,param="mi-async",value="on"
052,083 15^done
052,083 (gdb)
052,084 16-interpreter-exec console "set remotetimeout 60000"
052,086 =cmd-param-changed,param="remotetimeout",value="60000"
052,087 16^done
052,087 (gdb)
052,360 17-target-select extended-remote | crt_emu_cm_redlink -msg-port=49530 -g -mi -2 -pMKE15Z256x\
xx7 -vendor=NXP --connectscript=kinetisconnect.scp  --reset= -ProbeHandle=1 -CoreIndex=0 -cache=disa\
ble --flash-driver= -x /Users/high/Documents/MCUXpressoIDE_10.3.0/workspace/.mcuxpressoide_packages_\
support/MKE15Z256xxx7_support --flash-dir /Users/high/Documents/MCUXpressoIDE_10.3.0/workspace/.mcux\
pressoide_packages_support/MKE15Z256xxx7_support/Flash --telnet 3330
053,516 17^error,msg="Remote connection closed"
053,516 (gdb)
053,517 18-target-disconnect
053,517 19-gdb-exit
053,524 18^error,msg="You can't do that when your target is `exec'"
053,525 (gdb)
053,525 19^exit
————————————— Debug Messages —————————————
MCUXpresso IDE RedlinkMulti Driver v10.3 (Nov 28 2018 02:37:51 - crt_emu_cm_redlink build 748)
Found part description in XML file MKE15Z7_internal.xml
Reconnected to existing link server
Connecting to probe 1 core 0 (using server started externally) gave 'OK'
============= SCRIPT: kinetisconnect.scp =============
Kinetis Connect Script
Connecting to Probe Index = 1
This probe = 1
This TAP = 0
This core = 0
DpID = 0BC11477
Assert NRESET
Reset pin state: 00
Power up Debug
MDM-AP APID: 0x001C0020
MDM-AP System Reset/Hold Reset/Debug Request
MDM-AP Control: 0x00000008
MDM-AP Status (Flash Ready) : 0x00000036
Part is secured
Mass Erase Required
VID:PID:  0D28:0204
USB Path: USB_0d28_0204_fa140000_ff00
Connected&Reset. Was: NotConnected. DpID: 00000000. CpuID: 00000000. Info: <None>
ラベル(2)
1,329件の閲覧回数
jingpan
Hi Andre,
I guess your chip is locked. Please read this document for detail.
https://community.nxp.com/servlet/JiveServlet/download/2019-439921-857127-396709/Kinetis+Lock+issue+...
Jing
1,329件の閲覧回数
Frotz
Ah Ha!
Thanks, Jing. You've diagnosed it right-on. It was locked. I found a super simple way of unlocking a MCU in MCUXpresso that I thought I'd share with other novices so they can get going again easily:
Step 1: Open the GUI Flash tool
Step 2: Choose Resurrect locked...
Step 3: Hit Run.
In a moment the MCU will be unlocked and ready for more programming action!
Best,
Andre.
p.s. Thanks, NXP! This setup you have is the best I've ever seen on Macintosh for such embedded development!
1,330件の閲覧回数
jingpan
Hi Andre,
Jing
