An experiment -- Fast GPIO vs normal GPIO
Hi team ,
     I would like to share an experiment that about the Fast IO - zero wait state access of KL series . Detail please refer to attached file .
David
Comments
I have done some experimenting on FRDM-KL02Z32 and have problems with FGPIO switching performance with Bus Clock 4 MHz and below.
The 8MHz Bus Clock works normal 125 ns cycle per FGPIO switch, but with 4 Mhz Bus Clock, I get unstable switching from 250 ns to 500 ns.
To me it looks like System Clock and Bus Clock have synchronization problems.
I checked with FEI and 24 MHz divided down to Bus Clock  and also with IRC 4 MHz directly to Bus Clock in FBI mode same result.
Can someone recheck or explain?
%3CLINGO-SUB%20id%3D%22lingo-sub-1112683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAn%20experiment%20--%20Fast%20GPIO%20vs%20normal%20GPIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20team%20%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%20would%20like%20to%20share%20an%20experiment%20that%20about%20the%20Fast%20IO%20-%20zero%20wait%20state%20access%20of%20KL%20series%20.%20Detail%20please%20refer%20to%20attached%20file%20.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1112683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreedom%20Development%20Platform%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20L%20Series%20MCUs%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20An%20experiment%20--%20Fast%20GPIO%20vs%20normal%20GPIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20done%20some%20experimenting%20on%20FRDM-KL02Z32%20and%20have%20problems%20with%20FGPIO%20switching%20performance%20with%20Bus%20Clock%204%20MHz%20and%20below.%3C%2FP%3E%3CP%3EThe%208MHz%20Bus%20Clock%20works%20normal%20125%20ns%20cycle%20per%20FGPIO%20switch%2C%20but%20with%204%20Mhz%20Bus%20Clock%2C%20I%20get%20unstable%20switching%20from%20250%20ns%20to%20500%20ns.%20%3C%2FP%3E%3CP%3ETo%20me%20it%20looks%20like%20System%20Clock%20and%20Bus%20Clock%20have%20synchronization%20problems.%3C%2FP%3E%3CP%3EI%20checked%20with%20FEI%20and%2024%20MHz%20divided%20down%20to%20Bus%20Clock%26nbsp%3B%20and%20also%20with%20IRC%204%20MHz%20directly%20to%20Bus%20Clock%20in%20FBI%20mode%20same%20result.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECan%20someone%20recheck%20or%20explain%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎12-10-2015 09:29 AM
Updated by:
