Debug - how to display variable values while running debug
raybreslau
I'm used to using CodeWarrior with InDart One for debugging and I'm trying
to figure out how to achieve a similar view of variables when using KDS and
Multilink Universal.
BlackNight
Hi Ray,
the same is not possible with the normal GDB (which is used in KDS). The following article describes an approach to show variables while the target is running: Automatic Variable, Expression and Memory Display with GDB and Eclipse | MCU on Eclipse
Another approach is to use a target monitor program e.g. as used with FreeMaster (see Tutorial: FreeMASTER Visualization and Run-Time Debugging | MCU on Eclipse ).
I hope this helps,
Erich
